RV.Net Open Roads Forum: Solar Panels- Another Step Toward Independence
 > Solar Panels- Another Step Toward Independence
memtb
Wyoming
Posted: 09/30/20 04:01pm Link  |  Quote  |  Print  |  Notify Moderator
This should’ve been done a year ago.....but, life continually gets in the way! I’ve got to purchase some wire, junction boxes to finish the tie-in.
Installed these this morning on our Class C. The photo shows that the panels ( 4 x 100 watts) can be adjusted to take full advantage of the seasons/sun angle! memtb
Todd & Marianne
Miniature Schnauzer's - Sundai, Nellie & Maggie Mae
2007 Dodge Ram 3500, 6.7 Cummins, 6 speed manual, 3.73 ratio, 4x4
2004 Teton Grand Freedom, 39'
2007 Bigfoot 30MH26Sl
Camping near Pearsonville, CA
Posted: 09/30/20 04:11pm Link  |  Quote  |  Print  |  Notify Moderator
You’ll enjoy solar but tire of titling panels. Looks like a quality installation. Use adequately sized wire as determined by a good chart.
I use WindyNation’s at: https://www.windynation.com/jzv/inf/choosing-right-wire-size
pianotuna
Regina, SK, Canada
Posted: 09/30/20 05:06pm Link  |  Quote  |  Print  |  Notify Moderator
Hi memtb,
Consider using actuators for tilting. I can't imagine going up on the roof when it is raining and windy to strike the panels.
Regards, Don
gbopp
The Keystone State
Posted: 09/30/20 05:17pm Link  |  Quote  |  Print  |  Notify Moderator
Nice installation. [emoticon]
I agree, manually raising the panels would get old in a hurry.
jdc1
Rescue, Ca
Posted: 09/30/20 05:32pm Link  |  Quote  |  Print  |  Notify Moderator
And those roofs are not made to continuously walk on.
memtb
Wyoming
Posted: 09/30/20 06:20pm Link  |  Quote  |  Print  |  Notify Moderator
Yep, not much fun to spend time on the roof....especially with several inches of snow. We had tilt panels on our 5ers for years, and the older I get the harder it is.....I’ll have to look into actuators. The panels would only angled when we would be spending 2 to 3 or more days in one location, spring, fall or winter....but, that’s when we do the majority of our camping.
Pianotuna, can the actuators be had, to lift in two directions ,left or right?
jdc1, Thanks for the roof warning, however, we have a pretty heavy duty, well constructed unit! Zero to near zero flex when walking on the roof! memtb
* This post was edited 09/30/20 06:29pm by memtb *
FWC
The Wilderness
Posted: 09/30/20 08:15pm Link  |  Quote  |  Print  |  Notify Moderator
Agreed on the tilting panels, unless you are planning on staying in one location for a long time, it is unlikely that you will end up tilting them. Easier to add more panels than dealing with tilting.
On closer inspection, are your mounting brackets covering some of your solar cells? If so this can have a surprisingly large impact - reducing the current from ALL the cells in that string. It may be worth getting some narrower extrusions.
memtb
Wyoming
Posted: 09/30/20 08:24pm Link  |  Quote  |  Print  |  Notify Moderator
FWV, yes a very small strip of the panel is covered! memtb
pianotuna
Regina, SK, Canada
Posted: 09/30/20 10:39pm Link  |  Quote  |  Print  |  Notify Moderator
memtb,
I don't known if they are available in the format you want.
Tvov
CT
Posted: 10/01/20 05:15am Link  |  Quote  |  Print  |  Notify Moderator
I would think having to tilt the panels would depend on daily usage? Most days you should be fine with the flat panels? The tilt ability is there, if you need it.
Oh, and by the way... what a clean roof!
2008 F-250 CrewCab 5.4L,
