RV.Net Open Roads Forum: Tech Issues: How to spot a good disconnect switch?
 > How to spot a good disconnect switch?
wopachop
Who run bartertown
Posted: 09/30/20 06:45pm Link  |  Quote  |  Print  |  Notify Moderator
Some of the switches claim they are made of fine copper, instead of brass like the competitors.
Im looking at this switch and like its low profile. The pictures claim its made of copper, but it doesnt look like copper. Is it plated?
Is a sign of a good switch when its not plated and you can see its copper lugs?
https://www.amazon.com/gp/product/B07MQ5........e_dp_1?ie=UTF8&psc=1&smid=A1XLIDN9XQ0PZA
agesilaus
North Florida
Posted: 09/30/20 06:54pm Link  |  Quote  |  Print  |  Notify Moderator
I don't know but the BlueSeas and the Perkos are very popular and have been around a long time. More expensive tho.
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
FWC
The Wilderness
Posted: 09/30/20 07:38pm Link  |  Quote  |  Print  |  Notify Moderator
If you are concerned about the quality, spend a few extra dollars to buy one from a known manufacturer (BEP, Blueseas, Marinco, Perko etc):
www.amazon.com/BEP-701-Battery-Switches-On-Off/dp/B005DUUL9W
The one you linked to is probably fine, but there is no way to be sure.
Bobbo
Wherever I park
Posted: 09/30/20 07:52pm Link  |  Quote  |  Print  |  Notify Moderator
1. Quality
2. Cheap
Choose.
Bobbo and Lin
time2roll
Posted: 09/30/20 09:16pm Link  |  Quote  |  Print  |  Notify Moderator
Switch is fine. Should out last the RV.
675w Solar pictures back up
navigator2346
texas
Posted: 09/30/20 09:34pm Link  |  Quote  |  Print  |  Notify Moderator
These would be my choice
wopachop
Who run bartertown
Posted: 09/30/20 09:39pm Link  |  Quote  |  Print  |  Notify Moderator
Would you guys do something a little smaller and better looking for a solar panel disconnect?
wopachop
Who run bartertown
Posted: 09/30/20 10:03pm Link  |  Quote  |  Print  |  Notify Moderator
Here is how it looks. I normally dont have batteries installed. With the recent fires i put an old junky battery in there just to work the jack if needed. Thats why my solar is normally disconnected.
What do you think about cutting a small hole into the display itself? In the pics you can see the right side of the display does have a bit of room for a hole.
MrWizard
Traveling
Posted: 09/30/20 11:19pm Link  |  Quote  |  Print  |  Notify Moderator
I used a 50 Amp dc breaker for my solar panel disconnect switch in our previous RV
Found it on Amazon
Radiate The Happy
1997 F53 Bounder 36s
Boon Docker
Posted: 09/30/20 11:33pm Link  |  Quote  |  Print  |  Notify Moderator
Found it on Amazon
That is what I use also. Works just fine.
12V DC circuit breaker
