RV.Net Open Roads Forum: Tech Issues: short in wiring
 > short in wiring
trm3650
Casper, Wyoming
Posted: 10/01/20 08:50am Link  |  Quote  |  Print  |  Notify Moderator
hello, newbie here. say i am working on my jayco, i keep blowing a 15 amp fuse at the convertor, it goes to the A/C unit and the furnace, and of course the wall thermostat.as soon as i put in a new fuse it pops real fast, sometimes it will work for a bit when we put a fuse in it. would anyone have any ideas on where to start
Old-Biscuit
Verde Valley
Posted: 10/01/20 09:39am Link  |  Quote  |  Print  |  Notify Moderator
Hello trm3650 and Welcome!
Post Brand/Model of A/C Unit and Furnace and type of thermostat
15A is MAIN DC for controls
Typically that FUSE would feed DC directly to furnace and it then gets triggered by DC back from thermostat to start furnace FAN
Some designs have the DC going to a control module in A/C Unit
SO Bran/Models will be helpful
** I grew up in Casper
Went to East Jr High, Dean Morgan Jr High, Natrona County High and then Kelly Walsh where I graduated (Dad was oilfield and we moved to/from/back to Casper a LOT!)
rockylarson
Jersey Shore
Posted: 10/01/20 10:38am Link  |  Quote  |  Print  |  Notify Moderator
My converter only charges my batteries. From there the 12 volts are sent wherever it is needed. The fuses on my converter protect it from miswiring and/or reverse polarity from the incoming 120.volt system.
Good Luck and stay safe.
Jan and Rocky
Volunteers for USFWS. 25 refuges with 8000 hrs ea since 2006. 2004 Allegro 30DA, Workhorse 8.1, Banks, 2012 Jeep Liberty Jet, Blue Ox Aladdin, Brake Buddy Advantage Select, 300 watts solar, 5 Optima group 31 AGM's, 2000watt Ames PSW inverter.
trm3650
Casper, Wyoming
Posted: 10/01/20 10:42am Link  |  Quote  |  Print  |  Notify Moderator
A/C unit is coleman mach thermostat on wall is coleman also
pianotuna
Regina, SK, Canada
Posted: 10/01/20 10:59am Link  |  Quote  |  Print  |  Notify Moderator
A picture of the fuse and its location may be useful, too.
Regards, Don
shastagary
minnesota
Posted: 10/01/20 11:09am Link  |  Quote  |  Print  |  Notify Moderator
if you have a suburban furnace the wires have a plug in at the furnace unplug it and see if fuse still blows.
time2roll
Posted: 10/01/20 11:19am Link  |  Quote  |  Print  |  Notify Moderator
Stop blowing fuses and use a test light. When the light goes out you have removed the issue. Then you need to remove items systematically to identify where the problem exists. Easy to disconnect components to isolate the issue to be in the component or wire. Tracing an issue in the wire through inaccessible areas could prove difficult.
675w Solar pictures back up
Old-Biscuit
Verde Valley
Posted: 10/01/20 11:43am Link  |  Quote  |  Print  |  Notify Moderator
OK.....
But do you know which coleman mach A/C Unit is?
How about thermostat....old analog (slide controls) or digital (push buttons)
Furnace Brand/Model
Does it have external removable access panel?
Does it only have access from inside RV?
Also Post the year/brand/model of your RV
Trailer, MH
Really trying to HELP but w/o some details it is just a shot on the dark and guesses
MFL
Midwest
Posted: 10/01/20 12:05pm Link  |  Quote  |  Print  |  Notify Moderator
That info is a start, but as Old-Biscuit suggested, more details are needed. FYI...Old-Biscuit is very knowledgeable on these issues. You are lucky to have caught his attention. If you give the info needed, he is more likely than most, to help you solve this issue.
X2, welcome to the forum!
Jerry
trm3650
Casper, Wyoming
black with slide switches on bottom, black model just says coleman mach on it
 > short in wiring
