RV.Net Open Roads Forum: Only thing getting power is the 220V Appliance!?
 > Only thing getting power is the 220V Appliance!?
jeff_1981
Missouri
Posted: 10/01/20 02:38pm Link  |  Quote  |  Print  |  Notify Moderator
Hey electrical geniuses out there, I need your help. I know next-to-nothing about electrical. Maybe the answer is something simple. Either way, I don't know it, and I need some guidance, big time.
Wife and I are starting a mobile coffee and pastries business. Had an older camper fixed up. Looks great. Tried hooking it up to the generator today for the first time...and I'm perplexed. At first I thought nothing got power, but actually the 220V, 4000W, 20A espresso machine is the only thing that switches on. No other equipment or outlets work.
The generator is a Champion 8750 Watt Inverter, Model 100520. The plug going into the Camper is a big 4-Prong (I assume a 50A?). For the part going to the generator, I had to use a 30 Amp Generator 4 Prong to RV30 Amp Adapter cord I got from Home Depot.
I turn on the generator fine, I plug it in to the camper, and nothing. No lights go on. The refrigerator, kegerator, water heater, outlets, etc., nothing. EXCEPT that the humongous espresso machine (connected DIRECTLY to the breaker box, not an outlet) will switch on. Most of the outlets are GFCI, but none are tripped. I tried flipping off the circuit breakers for a while then switching back on. Nothing.
I. Don't. Get. It. And we can't even get a health inspection if we can't get the equipment running.... I had a theory that maybe the 30 Amp adapter cord was not enough? Maybe I need a 50 amp? I just don't know what to try.
HELP!!!!!!!!!
Dutch_12078
Winters south, summers north
Posted: 10/01/20 02:44pm Link  |  Quote  |  Print  |  Notify Moderator
Do you have a meter that you can use to check the voltages at the generator and other junctions along the way?
Dutch
2001 GBM Landau 34' Class A
jeff_1981
Missouri
Posted: 10/01/20 02:56pm Link  |  Quote  |  Print  |  Notify Moderator
I do! Where should I check and what reading should I be getting?
time2roll
Posted: 10/01/20 03:07pm Link  |  Quote  |  Print  |  Notify Moderator
The main breakers in the RV panel should have 240v between them.
Each breaker should measure 120v to the neutral bus.
Post the results
675w Solar pictures back up
2oldman
New Mexico
Posted: 10/01/20 03:09pm Link  |  Quote  |  Print  |  Notify Moderator
I'm perplexed here.
According to the pic of the generator, there's a 120/240 socket. Is that not a 50a 4-prong connector that your plug should fit into directly?
jeff_1981
Missouri
Posted: 10/01/20 03:47pm Link  |  Quote  |  Print  |  Notify Moderator
2oldman wrote:
I'm perplexed here.
All I know is the end of the cord I have has three prongs (two diagonal flat and one circle), and the only way I could connect it to the four prong locking female connector on the generator was to use this: https://www.homedepot.com/p/30-Amp-Generator-4-Prong-to-RV30-Amp-Adapter-cord-G30M4RV30F/202510179
Any chance I just need a new cord or adapter?
enblethen
Moses Lake, WA
Posted: 10/01/20 03:49pm Link  |  Quote  |  Print  |  Notify Moderator
Your adapter is not the correct one.
You need a L14-30 to 50 amp four prong.
Adapter
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
AllegroD
Outdare
Posted: 10/01/20 04:07pm Link  |  Quote  |  Print  |  Notify Moderator
Wait! Before you go buying stuff off of others recommendations, I think something is missing? Is you camper a 30 amp rig? Is it a trailer or MH? What make and model? That is what I think you are saying. Take a pic of the 120 volt circuit breakers and post them. Take a pic of your Auto Transfer switch, if you have one and post it here.
Photo Posting App page.
* This post was edited 10/01/20 04:14pm by AllegroD *
time2roll
Posted: 10/01/20 04:09pm Link  |  Quote  |  Print  |  Notify Moderator
If the trailer has a 4 prong main cord... you have the wrong adapter.
Lynnmor
Red Lion
Posted: 10/01/20 04:10pm Link  |  Quote  |  Print  |  Notify Moderator
There is no connection to the neutral, it is up to you to find it.
