RV.Net Open Roads Forum: electrical problem, lights above dinette will not shut off.
 > electrical problem, lights above dinette will not shut off.
EASY.RIDER
Mo
Posted: 10/01/20 03:42pm Link  |  Quote  |  Print  |  Notify Moderator
I have a winnebago aspect, 2014, 30-j unit. I have a electrical problem, the lights {2} above dinette will not shut off with the switch. The only way to shut them off is to shut down all power to the coach. I replaced the switch and again i have the same problem. I would appreciate any suggestions on this matter. thanks, tom
jdc1
Rescue, Ca
Posted: 10/01/20 03:49pm Link  |  Quote  |  Print  |  Notify Moderator
Try wiring the switch using the opposite wire as the cut off. It may be wired with the negative as the shut off. It should be the positive wire.
time2roll
Posted: 10/01/20 04:12pm Link  |  Quote  |  Print  |  Notify Moderator
Assuming the switch works... the light must remain on when the switch is removed.
675w Solar pictures back up
EASY.RIDER
Mo
Posted: 10/01/20 04:28pm Link  |  Quote  |  Print  |  Notify Moderator
These lights have worked fine since i bought the unit 5 years ago, until last week, however i did switch the wires,after i replaced the original switch but no change.
Dusty R
Charlotte Michigan 48813
Posted: 10/01/20 05:37pm Link  |  Quote  |  Print  |  Notify Moderator
If the power goes to the light first, then the 2 wires goes to the switch are shorted together, to prove this, disconnect one of them at the light.
Dusty
enblethen
Moses Lake, WA
Posted: 10/01/20 05:39pm Link  |  Quote  |  Print  |  Notify Moderator
Is the switch standard on/off?
Do you have switch number that you purchased. if so post?
How many pins or wires on the switch?
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
cavie
Posted: 10/01/20 05:42pm Link  |  Quote  |  Print  |  Notify Moderator
Do you have a volt meter? Do you know how to use it?
OLEJOE
N. Louisiana
Posted: 10/02/20 03:21pm Link  |  Quote  |  Print  |  Notify Moderator
Do they have the button on the bottom of them? Some of mine do and some don’t. May be a bad switch or shorted wiring. Find which wire is the hot wire and make sure it is on the correct terminal. Will the lights work with the switch removed?
