RV.Net Open Roads Forum: Tow Vehicles: Tail light wiring for towing
Search only in Tow Vehicles
 > Tail light wiring for towing
Wash41
Washingon
Posted: 10/03/20 12:56pm Link  |  Quote  |  Print  |  Notify Moderator
My 2020 Chevrolet Equinox was wired for towing. Now, when it rains or I go through a car wash, I get a signal that the tail lights are malfunctioning. The turn signals flash quickly similar to a burned out bulb. After a couple days, it returns to normal function. RV dealer technician is unable discover source
jdc1
Rescue, Ca
Posted: 10/03/20 01:08pm Link  |  Quote  |  Print  |  Notify Moderator
Find a different GM service.
Turtle n Peeps
California
Posted: 10/03/20 01:34pm Link  |  Quote  |  Print  |  Notify Moderator
Could be a few things but #1 on my list would be a ground issue.
outside the fire"
"The best way to get a bad law repealed is to enforce it strictly."- Abraham Lincoln
Beverley&Ken
Tottenham,Ontario
Posted: 10/03/20 01:41pm Link  |  Quote  |  Print  |  Notify Moderator
Rain, car wash = moisture across electrical connections, especially when it clears up after a couple of days. It could be at the module that is plugged in to the car wiring harness, if in an where water could be present.
The first place that I would check would be the receptacle on the front of the car to make sure that it is dry and clean. If the cover seal is not good, the receptacle could be filling with water, consequently shorting across the terminals.
Use electrical contact grease on all connections, umbilical cord to car and even on the module (if you have one) to help eliminate moisture issues.
Ken
2006 Winnebago Outlook 29B E-450.
2012 Honda CR-V AWD
Blue Ox Aventa LX tow bar and Brake Buddy Vantage.
Posted: 10/03/20 02:02pm Link  |  Quote  |  Print  |  Notify Moderator
Depending which side of the stage you’re on depends how long you got before this is a daily issue ! Lol
If it’s the place they installed it, raise he!!
If it’s not, then find someone else to fix it or trace the work that was done to find the connections susceptible to water.
ktosv
Grand Rapids, MI
Posted: 10/03/20 02:04pm Link  |  Quote  |  Print  |  Notify Moderator
When you say wired for towing, from the factory or you took it somewhere?
Kevin and my...
Wife and six kids
2017 Suburban (5.3L/6A/3.08)
6x12 Enclosed Utility
Sold...2011 Express 3500 (6.0L/6A/3.42)
Sold...2010 Passport Ultra Lite 2910
Chuck ..
Salem, Oregon
Posted: 10/03/20 09:32pm Link  |  Quote  |  Print  |  Notify Moderator
If anyone is have problems with your truck display not recognizing that the trailer is connected your left and right turn signal flashing rapidly in the truck, here is the solution. This connector will save your days and hours trying to hunt down the problem.
Curt
7-Way RV Blade LED Electrical Adapter (Not a Wiring Extension) #57003
MSRP $31.75 USD
Enables vehicles with a 7-way RV blade socket to recognize LED trailer lights 7-Way RV Blade LED Electrical Adapter (Not a Wiring Extension) #57003
MSRP $31.75 USD
Built-in, integrated resistors for computers that don't recognize LED lights
7-way connects tail, brake, reverse, turn signals, brakes and auxiliary power
Simple plug-and-play design eliminates the need for cutting or splicing
Spring-loaded dust cover keeps connector clean when not in use
Chuck
Dadoffourgirls
China, MI USA
Posted: 10/04/20 12:48am Link  |  Quote  |  Print  |  Notify Moderator
I second KTSOV with his question. Does your Equinox have the 2.0T engine that came with the hitch and tow wiring? If so, take it back to the dealer for warranty service.
If it was wired by the RV store, the wiring harness they used plugs into the light socket, and then the harness socket to the light. They did not get the socket sealed correctly, and moisture is getting to the taillight electrical system or into the trailer plug causing the issue. Was it installed on the exterior of the vehicle?
I installed my 4-way plug to be inside the vehicle and just hang out the hatch when needed.
Dad of Four Girls
Wife
Employee of GM, all opinions are my own!
2017 Express Ext 3500 (Code named "BIGGER ED" by daughters)
2011 Jayco Jayflight G2 32BHDS
bikendan
Camano Island, Wash.
Posted: 10/04/20 02:53am Link  |  Quote  |  Print  |  Notify Moderator
i can't tell if the OP is talking about towing with the Equinox or using it as a toad.[emoticon]
Dan- Firefighter, Retired">, Shawn- Musician/Entrepreneur">, Zoe- Faithful Golden Retriever(RIP">), 2014 Ford F150 3.5 EcoboostMax Tow pkg, 2016 PrimeTime TracerAIR 255 w/4pt Equalizer and 5 Mtn. bikes and 2 Road bikes
