RV.Net Open Roads Forum: Truck Campers: 2002 Lance 811 Rebuild: Rig is Ready!
 > 2002 Lance 811 Rebuild: Rig is Ready!
BurbMan
Noblesville, IN
Posted: 10/05/20 08:34am Link  |  Quote  |  Print  |  Notify Moderator
Finally got the Lance on the truck and drove it around some yesterday!
The HappiJac Qwik-Loads that came with the camper cleaned up nice! Polished them up and hopefully keeps the rust at bay. Really wanted a new set of Fast Guns but couldn't swallow that cost after laying out for the Torklift frame mounted tie downs. So a little 3/8" galvanized chain makes up the difference.
According to my measurements I needed to add some height so I put the camper on top of a pair of 2x10s in the truck bed. The 1-1/2" was just what I needed to give me good clearance over the roof lights and bed sides. I also laid a 2x4 on edge across the front of the bed, to space the camper 1-1/2" back from the front.
When I bought this truck the PO had added a "leveling kit" which is basically a 1-1/2" space that sits on top of the front coil springs, he needed this for clearance on the 325 tires that are technically too big for 8" rims. Looks bada$$ when it's empty but looks overloaded with a load on it. I can't lose the spacers without going to smaller tires, so that will be a next year project.
The new umbilical cord worked out good too. It does drop the charging lines from #8 to #10, but since I swapped the 3-way fridge for a 2-way, that hi amp capacity is no longer needed. I have 100w solar helping to keep the battery up.
Open to to any comments and suggestions, and I can post more pics if you want to see something specific. This has been a great project and appreciate the help from everyone here!
I still need to buff out the original fiberglass remaining on the slide out and back walls and get some kind of graphics on it. For now I'm excited to go somewhere next weekend! Need to get at least one trip in before the winter!
* This post was edited 10/05/20 08:40am by BurbMan *
SOLD: 2008 Terry 34' TT
SOLD: 2001 K2500LT 8.1L Suburban
Lance 811 Renovation Story!
Project Complete!
Maiden Voyage!
Fishbreath
home
Posted: 10/05/20 09:35am Link  |  Quote  |  Print  |  Notify Moderator
Glad you are happy with your set up! In your third picture, it appears that the floor is coming apart on the left side. I would question your use of just two 2x6's instead of supporting the camper floor evenly (Thinking plywood platform or rubber horse mat)
Posted: 10/05/20 09:51am Link  |  Quote  |  Print  |  Notify Moderator
Nice work Burb Man!
2017 Heartland Torque T29
BurbMan
Noblesville, IN
Posted: 10/05/20 12:04pm Link  |  Quote  |  Print  |  Notify Moderator
Good eye...actually the umbilical is pinched between the floor and the 2x10. That part of the floor is sheet metal that that goes under the holding tanks. What you are seeing under the access door to the dump valves is a removable piece that enables you to connect the dump hose. Having the cord pinched in there pushed that sheet metal out of alignment somewhat. I can tell you the floor is solid because I replaced that section under the door!
jaycocreek
Idaho
Posted: 10/05/20 12:14pm Link  |  Quote  |  Print  |  Notify Moderator
Nice job...
Williams AZ area
Posted: 10/05/20 12:42pm Link  |  Quote  |  Print  |  Notify Moderator
What a good looking rig!
Bert the Welder
Van. Island
Posted: 10/05/20 12:58pm Link  |  Quote  |  Print  |  Notify Moderator
Congrats! Look great!
"> 1998 GMC 2500, 10.5 Okanagan, My better/smarter half, George and Finnegan(APBT), all I need.
Seminoe Joe
Texas, Wyoming, or somewhere in between
Posted: 10/05/20 06:30pm Link  |  Quote  |  Print  |  Notify Moderator
Mighty fine looking camper! Enjoy her on the maiden voyage!
β€œIt’s all in the reflexes.”
2012 Lance 850
2012 Chevy 2500 HD
dhull
apple valley
Posted: 10/06/20 03:51pm Link  |  Quote  |  Print  |  Notify Moderator
Awesome work! I wish you had made my camper.
K Mac
Lower Hudson Valley N.Y.
Posted: 10/06/20 07:29pm Link  |  Quote  |  Print  |  Notify Moderator
Congrats on finishing your project, looking good. Two weeks back, the western Catskills, were just showing some nice color change, if that's your thing.
