RV.Net Open Roads Forum: questions on parking dp vs gas on grass
 > questions on parking dp vs gas on grass
onrecess
Boca Raton, FL
Posted: 10/05/20 09:42am Link  |  Quote  |  Print  |  Notify Moderator
I hope this isn't too dumb a question... When I see a DP for sale, like online, is that the height they are going down the road or does the air ride raise it more? My 2005 Georgie Boy 35 gasser is parked next to my house, on a gravel pad. I back it up over my yard. Is the DP lower? The gasser is already pretty low, the jacks aren't very high off the ground. I don't think anything lower will work without having the yard recontoured. Also, can I back it over the yard? It looks like a 45 dp with tag is twice as heavy. Can you lift the coach with the tag or with the air bags without modification? Finally, my grave pad is about 4 or 5 inches deep of big 2 inch rocks. It is level, so the gasser parks there and doesn't sink, I assume a DP would be okay? I'm hoping to move in a year or so, so I don't want to put in a new concrete drive and pad.
I'd hate to buy it and not be able to park it! Every storage place I've parked I ended up with busted mirrors, scrapes, and $$ repairs. Covered storage is like $500+ a month!!! Yikes!
Tom Anderson
2005 GeorgieBoy 35
jorbill2or
Full time
Posted: 10/05/20 09:56am Link  |  Quote  |  Print  |  Notify Moderator
Dp,s I’ve had all sit lower than gassers. In many cases you can raise them with the air bags but only while holding the raise switch , they return to ride height as soon as you release the switch.
Personally I wouldn’t be driving on grass that wasn’t bone dry and hard packed . The weight and highway tires can get you stuck ( personal experience ) very quickly. I park on my bro in laws gravel pad when we visit and the gravel compresses to tracks so I quests gravel if compacted like a driveway is fine but it needs to be compacted.
If it’s close by maybe a test park just to make sure ?
Bill
onrecess
Boca Raton, FL
Posted: 10/05/20 09:59am Link  |  Quote  |  Print  |  Notify Moderator
Thanks Bill. How high does it go with the raise switch? I'd only have to go 40 ft, I assume I could drive it that far raised?
jorbill2or
Full time
Posted: 10/05/20 10:02am Link  |  Quote  |  Print  |  Notify Moderator
Never measured ... 6” maybe
. And yes just hold the raise switch . I use it if I’m in a sloped drive so I don’t drag the rear. Good luck !
onrecess
Boca Raton, FL
Posted: 10/05/20 10:07am Link  |  Quote  |  Print  |  Notify Moderator
Wow! 6" is a lot higher than I expected. An extra 6" would be easy. My jacks aren't 9" off the ground on my gasser.
Executive
Posted: 10/05/20 12:27pm Link  |  Quote  |  Print  |  Notify Moderator
My coach weighs in at 49,650 pounds. Make sure your 'grass' can hold that. Also, pray it doesn't rain just before you're ready to head out. DPs are much heavier than gassers.....Dennis
We can do more than we think we can, but most do less than we think we do
Dennis and Debi Fourteen Years Full Timing
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
Williams AZ area
Posted: 10/05/20 12:39pm Link  |  Quote  |  Print  |  Notify Moderator
I've seen many a DP sunk in grass. Be careful.
Blaster Man
Posted: 10/05/20 01:55pm Link  |  Quote  |  Print  |  Notify Moderator
Executive wrote:
....DPs are much heavier than gassers.....D
Yes, the most important difference.
2014 American Eagle
Bruce Brown
Northern NY
Posted: 10/05/20 07:11pm Link  |  Quote  |  Print  |  Notify Moderator
I drive on grass all the time. We park there too. Unless its extremely wet its never been an issue.
As to the height question, ours raises a bunch when its aired up.
There are 24 hours in every day - it all depends on how you choose to use them.
Bruce & Jill Brown
2008 Kountry Star Pusher 3910
craig7h
Branson MO area
Posted: 10/06/20 04:04am Link  |  Quote  |  Print  |  Notify Moderator
If I read your question correct, with the motor running the air bags will inflate. This will cause the coach to raise up, which will make it higher off the ground. Thus over all height will be higher than gasser. Once you turn things off one of two things will happen air bags will stay up or deflate . I have an older coach my air bags will deflate as soon as I start the jacks to go down. If I do not do the jacks the bags will slowly loose air. For ground to frame height remember dp tires are larger also.
I get really worried any time I deal with grass. Either driving on or parking on. Was at a rally couple years back, was parked on grass. Saw three dp sunk up to axels trying to get out. My jacks with enlarged foot print sunk two inches. You be the judge
Itasca Meridian SE 36g
Road Master Tow Dolly
