RV.Net Open Roads Forum: Fifth-Wheels: 5th wheel adapter for goose neck
 > 5th wheel adapter for goose neck
SUMRX4
VA
Posted: 10/05/20 09:56am Link  |  Quote  |  Print  |  Notify Moderator
Just something I have noticed around in campgrounds but why do some people convert their 5er to a goose neck? Is there a difference in towing or is it usually done by folks that own additional goose neck trailers so they don't need to switch hitches in truck bed?
Just curious
Old-Biscuit
Verde Valley
Posted: 10/05/20 10:00am Link  |  Quote  |  Print  |  Notify Moderator
Most likely ...multiuse
But there are some that think it is better
Biggest issue is 5th wheel pin box frame/structure are NOT designed for that type of strain/pressure
Just look at how a gooseneck trailer is built vs a 5th wheel overhang frame
jdc1
Rescue, Ca
Posted: 10/05/20 10:02am Link  |  Quote  |  Print  |  Notify Moderator
And then their are those that think a goose-neck is "all that".
kmac7800
Richland
Posted: 10/05/20 11:05am Link  |  Quote  |  Print  |  Notify Moderator
He may be referring to a "goosebox" which does not cause issues with your chassis warranty. The one I am thinking of is made by Reese, however there is another out there that I have seen but do not remember the manufacturer.
Oh, and I would use it (if I could) so I do not have to remove a 250lb fifth wheel hitch in/out of my truck bed if I wanted to use my pickup as a... well... pickup.
//KMac
BB_TX
McKinney, Texas
Posted: 10/05/20 11:15am Link  |  Quote  |  Print  |  Notify Moderator
Probably people who have other gooseneck trailers. And/or those who grew up with or worked with farm, stock, and implement gooseneck trailers. But those are designed specifically for the gooseneck hitch.
The rigid gooseneck adapters for 5ers put stresses on a trailer frame that a standard 5th wheel hitch does not. And some manufacturers will void the warranty on a new 5th if you use one. But, having said that, many do it any way and seem to have no problem with them. The Goosebox (with air ride and shock absorber) is the only one I have heard of that is actually acceptable to some manufacturers.
valhalla360
No paticular place.
Posted: 10/05/20 12:59pm Link  |  Quote  |  Print  |  Notify Moderator
A goosneck where the ball is at the floor of the pickup bed, creates a longer leaver arm on the trailer frame. If it's a light weight trailer with an overbuilt frame, that may be OK. If it's heavier and not built so well, it can be a problem...particularly if you are on rough roads. These variations in weight and driving conditions explain why some people go years with no issues and others quickly break something in the frame.
You may occasionally see a mount where it's a gooseneck ball but on a raised frame, pretty much the same height as a regular 5th wheel hitch. That shouldn't have any impact on the stress the trailer frame sees as the lever arm is roughly the same.
As to why? Most already have a gooseneck ball in the truck and it takes up very little space when not towing...vs a big heavy hitch that eats up a 1/3 of the truck bed when not towing.
Tammy & Mike
Ford F250 V10
2008 Copper Canyon 5er
Catalac Catamaran 34'
Full Time spliting time between boat and 5er
BB_TX
McKinney, Texas
Posted: 10/05/20 01:08pm Link  |  Quote  |  Print  |  Notify Moderator
Also you are supposed to use safety chains with a gooseneck hitch. Although it is questionable how many “forget” or never know that.
garyp4951
TN
Posted: 10/05/20 06:56pm Link  |  Quote  |  Print  |  Notify Moderator
The Reese Goosebox, and Gen-Y are the new kids on the block, and are said not to damage the FW frame.
NJRVer
NJ
Posted: 10/05/20 07:15pm Link  |  Quote  |  Print  |  Notify Moderator
But do manufacturers recognize them or still say no to a gooseneck?
Reese and Gen-Y may say they are good, but if something happens will your trailer company tell you tough luck?
Michelle.S
Western NY till fall, then Sebring, FL
Posted: 10/05/20 07:43pm Link  |  Quote  |  Print  |  Notify Moderator
Lippert has approved the Reese Goose Box for use with their Frames.
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
