Geewizard
WA
I haven't used my TC since last fall so now it's been a year since I filled the water system with potable antifreeze. And I have no plans to use the TC until next spring at the earliest....when a Covid-19 vaccine is available.
Do I need to change it since it's a year old?
2004 Outfitter Apex 8
2014 Toyota Tundra Double Cab
200W solar, MPPT controller, LED lights
Wave 3 Heater
Air Lift WirelessAIR and air bags
Hankook Dynapro ATM 10-ply tires
rockylarson
Jersey Shore
The only potable antifreeze I know of keeps for many years, comes in 80-150 proof, and sometimes gets better with age. The pink winterizing solution you are referring to is sometimes captured after each season and used over and over again.
I am sure you will be OK.
Jan and Rocky
Volunteers for USFWS. 25 refuges with 8000 hrs ea since 2006. 2004 Allegro 30DA, Workhorse 8.1, Banks, 2012 Jeep Liberty Jet, Blue Ox Aladdin, Brake Buddy Advantage Select, 300 watts solar, 5 Optima group 31 AGM's, 2000watt Ames PSW inverter.
sbryan@vtbryans.com
Vermont
If you haven't diluted it or used it then no, the antifreeze should be fine for another winter.
Shawn
2013 Ford F350 6.7 CCLB Ruby Red SRW, sway bar, Bilsteins, etc
2007 Cyclone toyhauler, 18,000 GVWR
Northstar Igloo 9.5
https://photos.smugmug.com/photos/i-2J3zF6J/0/M/i-2J3zF6J-M.jpg
US Army retired
time2roll
Would not hurt to blow it out if you are concerned.
675w Solar pictures back up
sljohnson1938
Mount Airy, NC - USA
i agree with time2roll - it does not cost that much for the peace of mind.
will take only a few minutes to flush out the old and put in new anti-freeze.
1999 Dodge 3500 CTD dually
Ham radio - WU4S
jesseannie
Roseburg, OR
Don't drink the pink!
specta
utah
Sorry you didn't get to use you camper this year.
Kenny
2011 Chevy 2500 HD 6.0L 4wd
6580 lb truck 10540 fully loaded
jimh425
Western MT
I would change it just because it probably doesn’t even take a 1/2 gallon.
ticki2
NH
I have a similar situation with a TT . I'm going to leave it but I'm going to refill the sink and shower trap because I'm not sure if it evaporates . I will leave some in an open bowl this winter to test .
'68 Avion C-11
'02 GMC DRW D/A flatbed
jimh425
Western MT
Good idea about the traps and toilet. I just winterized although I’m going to use mine, so it will be an off/on kind of deal for me.
