RV.Net Open Roads Forum: Truck Campers: Leaving potable antifreeze in the system
 > Leaving potable antifreeze in the system
Page of 5
Geewizard
WA
Posted: 10/05/20 06:58pm Link  |  Quote  |  Print  |  Notify Moderator
specta wrote:
Sorry you didn't get to use you camper this year. [emoticon]
Me too. Thanks.
2004 Outfitter Apex 8
2014 Toyota Tundra Double Cab
300W solar, MPPT controller, LED lights
2 Fullriver 100AH AGM batteries
Compressor fridge
Wave 3 Heater
Air Lift WirelessAIR and air bags
Hankook Dynapro ATM 10-ply tires
Geewizard
WA
Posted: 10/05/20 07:00pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all the input.
Now, I'm concerned about the fresh water tank growing mold. I think a half cup of bleach might be a good idea.
Thoughts on that?
jimh406
Western MT
Posted: 10/05/20 07:07pm Link  |  Quote  |  Print  |  Notify Moderator
Put the bleach when you dewinterize it.
Terryallan
Foothills NC
Posted: 10/05/20 07:15pm Link  |  Quote  |  Print  |  Notify Moderator
Guess whay i learned this year? The pink stuff turnes to jelly after a while. Yes it does. I had some in my fresh tank for a few years, and it gelled right up. I like to never got it washed out of the fresh tank.
I would suggest changing it no later than next year. If not this year. It's cheap.
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
Geo*Boy
Unknown
Posted: 10/05/20 07:33pm Link  |  Quote  |  Print  |  Notify Moderator
Thoughts on that?
If that’s the case, load the camper, 1/2 cup of bleach to 15 gallons of water, dewinterize with bleach water, take the camper for a ride around the block to coat the tank, let it sit for a couple of hours, drain and winterize with the pink stuff. Two gallons of pink only cost $6.00.
Slymer
Ontario, Canada
Posted: 10/05/20 07:36pm Link  |  Quote  |  Print  |  Notify Moderator
I am not sure what the point of putting pink into a drained fresh tank would be, at any time let alone for a few years. In any case to winterize I blow out the lines, then flow the pink through, then blow out again. Makes is so much easier to get the pink taste/smell out of the lines in the spring because it hasn't been eating into the lines all winter.
billtex
RI
Posted: 10/05/20 08:08pm Link  |  Quote  |  Print  |  Notify Moderator
jimh425 wrote:
I would change it just because it probably doesn’t even take a 1/2 gallon.
Good time to change the air in your tires too.
2020 F350 CC LB
Eagle Cap 850
25'Airstream Excella
"Good People Drink Good Beer"-Hunter S Thompson
dieseltruckdriver
Black Hills of SD
Posted: 10/05/20 08:34pm Link  |  Quote  |  Print  |  Notify Moderator
I do mostly the same, I just drain the water, I don't blow it out. Then I run pink through it, then drain that and use the freshly drained stuff in the toilet and sink drains.
I would never put anything in the fresh tank, other than fresh water. Remember, ice cube trays don't break, and if your fresh tank is drained, what little is left won't matter.
2000 F-250 7.3 Powerstroke
2018 Arctic Fox 27-5L
jimh406
Western MT
Posted: 10/05/20 09:01pm Link  |  Quote  |  Print  |  Notify Moderator
Not exactly the same thing because RV antifreeze isn't stable. Did you miss the post that said RV antifreeze turns into a gel?
dieseltruckdriver
Black Hills of SD
Posted: 10/05/20 09:09pm Link  |  Quote  |  Print  |  Notify Moderator
I would agree with this. At the price of the stuff, just flush it out with new. It only takes a few minutes and about $7.00 to refresh it.
Then when you get it ran through the lines, drain it and don't worry about the gel problems.
Page of 5
