RV.Net Open Roads Forum: Class A Motorhomes: Blown engine
 > Blown engine
Bird Freak
Dallas Ga.
Posted: 10/05/20 07:32pm Link  |  Quote  |  Print  |  Notify Moderator
Just a word of warning. DO NOT buy a Jasper rebuilt engine. They will not stand behind their engines.
Eddie
03 Fleetwood Pride, 36-5L
04 Ford F-250 Superduty
15K Pullrite Superglide
Old coach 04 Pace Arrow 37C with brakes sometimes.
Owner- The Toy Shop-
Auto Restoration and Customs 32 years. Retired by a stroke!
We love 56 T-Birds
grldst
Dallas, GA
Posted: 10/05/20 08:00pm Link  |  Quote  |  Print  |  Notify Moderator
Do some shopping around. You should be able to get the job done for about half what that dealer quoted. Lots of those engines on the internet with warranty for 4-5000. Visone RV salvage has some low mileage 8100's from 3-4000.00
ppine
Northern Nevada
Posted: 10/05/20 08:59pm Link  |  Quote  |  Print  |  Notify Moderator
Try a used engine, maybe you can find a diesel.
Edd505
Elephant Butte, NM
Posted: 10/05/20 09:10pm Link  |  Quote  |  Print  |  Notify Moderator
This is good advise shop around and have it towed to a repair shop. I'm sure there are some good used engines around, or Internet rebuilt short blocks and use whats still good on yours. I use a local shop that is 1/2 the shop rate of dealerships. Someone pays for that pretty building they are in. I was a Ford/Lincoln/Mercury mechanic coming home from Vietnam.
2015 F350 FX4 SRW 6.7 Crew, longbed - 2017 Durango Gold 353RKT
2006 F350 SRW 6.0 crew longbed sold
2000 F250 SRW 7.3 extended longbed airbags sold
2001 Western Star 4900EX sold
Jayco Eagle 30.5BHLT sold, Layton 24.5LT sold
down home
south
Posted: 10/05/20 10:16pm Link  |  Quote  |  Print  |  Notify Moderator
A crate GM 572 dart block, ready to run long block on ebay 745 hp 700+ft lb of torque $10,000.00 and change. A hot rod engine a bit much?
You can find factory new crate 454 ci engines from a bit over $5,000.00. If you go the time to shop via phone, you can have one of the builders put a cam suitable for a Mh in the engine. They must be charging a lot for removal and installation, which can be a challenge I'm sure.
Just an option. If your insurance is handling it let them do their thing and they might even rent a car for you for a period of time.
Dealers are gettign really out of lien today on prices on everything. Son' 07 Soltice jsut had the A/c reworked and then it quit again. $400.00 for a half hours work and four sensors that would coat after market $20.00 each at the mos
If I was younger you give me a check for that amount, I'll give you a motorhome ready for super Stock, so to speak, not literally.
On edit, of course you put in a stouter engine more heat so bigger radiator and oil cooler and trans and cooler. And long tube approprate headers will help with cooling. The mufflers would be bigger of course.
rgatijnet1
Posted: 10/06/20 04:19am Link  |  Quote  |  Print  |  Notify Moderator
Just make sure that you find out what caused the problem. A bad MAF has been known to make the engine run lean and burn a piston. There could also be an issue with the ECM or O2 sensors.
Basically you want to make sure that if you get a new long block that you do not use any bad components from your old engine when you bolt on all of the accessories.
midnightsadie
ohio
Posted: 10/06/20 04:42am Link  |  Quote  |  Print  |  Notify Moderator
x2 don,t let the dealer do it, they just rip you off . find a mom,pop shop for half that money and a better job.
BurbMan
Islip, Long Island
Posted: 10/06/20 07:10am Link  |  Quote  |  Print  |  Notify Moderator
How many miles on your 8.1? I had 183k on my Suburban and the motor was still strong when I sold it. If you opt for a replacement engine vs a the dealer rebuild, watch what you are buying. The 8.1 is not the same as the 454, and 8.1's were built for several applications, so be sure to get one that was built for an RV application, not built for racing.
SOLD: 2008 Terry 34' TT
SOLD: 2001 K2500LT 8.1L Suburban
Lance 811 Renovation Story!
Project Complete!
Maiden Voyage!
JJ927
Space Coast
Posted: 10/06/20 08:28am Link  |  Quote  |  Print  |  Notify Moderator
Only 52K, but it sat in Florida for years without running, so the who knows what condition the inside of the engine is in.
2004 Georgie Boy Landau 3525TS
JJ ">, JP ">, Linus & Dexter (Dachsunds) ">
RLS7201
Posted: 10/06/20 04:48pm Link  |  Quote  |  Print  |  Notify Moderator
Don't think GM built any 8.1 (496) for racing. But there were a ton of 502 big blocks built for racing.
Richard
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
First brake job
1941 Hudson
 > Blown engine
