RV.Net Open Roads Forum: Tech Issues: Norcold N811 fridge-no power
 > Norcold N811 fridge-no power
agesilaus
North Florida
Posted: 10/06/20 11:53am Link  |  Quote  |  Print  |  Notify Moderator
OK we have a Norcold N811 and it was working fine a few weeks ago. We powered it fdown when we got home. When I tried to power it up again to get ready for another trip the display is blank and it does not respond to the on/off switch.
1) 12V Fuse is OK
2) Checked 120V outlet that the fridge is plugged into with an outlet tester and it is fine.
3) Propane is OK, runs stove burners and oven OK
so this seems to come down to the circuit/power board.
I don't know where the power board is tho, is it inside this black box in the outside access hatch?
Also how can you get to the on/off switch, there doesn't seem to be any way to open the panel. Do you have to pull the fridge out from the wall?
Thanks for any help or suggestions.
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
Old-Biscuit
Verde Valley
Posted: 10/06/20 12:39pm Link  |  Quote  |  Print  |  Notify Moderator
Have to have 12VDC TO the fridge before ANYTHING will work
No DC...NOTHING works (Display, control panel, interior light, AC Element etc)
That Black box ....cover for circuit board
On the Circuit board at couple of fuses
Glass 5A for the AC Element
Auto Blade 5a for ALL DC
Also the RV Main DC Fuse goes to 12VDC+ Terminal on circuit board (Yellow wire?) and GND1 Terminal (Neg) S/B White wire
See Pg 11 for DC information
See Pg 45/46 about removing cover on lower circuit board AND the display control panel
N6XX/N8XX Service Manual
Picture of a Norcold N6XX/N8XX circuit board
* This post was edited 10/06/20 12:59pm by Old-Biscuit *
Flute Man
Payson, Arizona
Posted: 10/06/20 04:54pm Link  |  Quote  |  Print  |  Notify Moderator
You might make sure that the 12 V battery is not discharged.
Jerry Parr
05 Mandalay 40B
Cat C7 350
04 Honda CR-V
Ham Radio K7OU
Retired EE
Jrparr32@gmail.com
602-321-8141
Full-timer
agesilaus
North Florida
Posted: 10/06/20 05:02pm Link  |  Quote  |  Print  |  Notify Moderator
I have a bank of four six volt golf cart batteries and have a volt meter on the 12V bus. All is well there and all the other 12V gear is working. I'll pull that black box off in the morning to check the fuse and I'll check voltages on the board too. I'll call the mobile RV guy if I don't figure it out in the AM.
Itinerant1
Itinerant
Posted: 10/06/20 07:42pm Link  |  Quote  |  Print  |  Notify Moderator
This is what's behind that black plastic box.Arrows are to the fuses.
12v 500ah (5,120Wh usable) , 20 cells_ 4s5p (GBS LFMP battery system). 8 CTI 160 watt panels (1,280 watts) 2s4p. Panels mounted flat on the roof. Magnum PT100 controller, Magnum 3012 hybrid inverter, ME-ARC 50. Installed 4/2016 been on 24/7/365
Old-Biscuit
Verde Valley
Posted: 10/06/20 09:32pm Link  |  Quote  |  Print  |  Notify Moderator
That doesn't look like a circuit board for the Norcold N811 like OPs fridge model
Itinerant1
Itinerant
Posted: 10/06/20 10:26pm Link  |  Quote  |  Print  |  Notify Moderator
You're correct it's an 821, I had to look at my fridge for some reason I was thinking it was an 811. My apologize. [emoticon]
dougrainer
Carrolton, Texas
Posted: 10/07/20 07:24am Link  |  Quote  |  Print  |  Notify Moderator
How come NOBODY has stated the obvious FIRST thing to check? The Hi temp switch On the Cover of the FLUE????????? Doug
Old-Biscuit
Verde Valley
Posted: 10/07/20 09:02am Link  |  Quote  |  Print  |  Notify Moderator
Ding, Ding, Ding......winner/chicken dinner!
dougrainer
Carrolton, Texas
Posted: 10/07/20 09:45am Link  |  Quote  |  Print  |  Notify Moderator
I was shocked you did not mention it. Doug
