RV.Net Open Roads Forum: Fifth-Wheels: Gate valves
 > Gate valves
routemaster
Deming
Posted: 10/06/20 04:19pm Link  |  Quote  |  Print  |  Notify Moderator
Any one have a PDF file of the tank layout and were the gate valves locations in a 2017 LM 365 Arlington?
Please.
Den.
2017 Landmark Arlington 365
2015 Silverado LTZ 3500 c/c LWB.
alboy
Kelowna B.C.
Posted: 10/07/20 09:41am Link  |  Quote  |  Print  |  Notify Moderator
We have a landmark savannah ,i would say the set up is similar with 2 gray and the black.The front grey and black are tucked up just in front of the frame drop.The rear grey is also tucked up high near the left frame rail.To access you will have to drop maybe 4-5 ft of the left side coroplast from the frame drop back.BIN There.
routemaster
Deming
Posted: 10/07/20 01:08pm Link  |  Quote  |  Print  |  Notify Moderator
Hi Alboy. Thanks. I have a gray valve is not closing up. I didn't want to remove all the belly and was looking for were to make the cuts right beneath the gate valve . I have tried to get the info but no luck maybe a dimensions from some were on the coach to the valve location.
Thanks.
 > Gate valves
