RV.Net Open Roads Forum: Winterizing TT for 1st time and have a ??? about the toilet.
 > Winterizing TT for 1st time and have a ??? about the toilet.
bacabunch
Idaho
Posted: 10/09/20 05:42pm Link  |  Quote  |  Print  |  Notify Moderator
Howdy,
We just purchased a Springdale TT with toilet cleaning system. I flushed the line several times and still see some residue down in the line. I plan on blowing out the supply lines. Is it common to have about an inch of water down in the toilet drain?
"White Knuckles" Ben ">
2020 Springdale 282BH Travel Trailer pulled by a 2015 Chevy 2500HD Silverado LB.
Ben">Marisela">Natalie">Maria">Emily">Matthew">Abby>JoeJoe: Bogey(Westie)"> Gracie(Shih Tzu) "> Daisy (Yorkie)
Death Valley NP
Posted: 10/09/20 05:59pm Link  |  Quote  |  Print  |  Notify Moderator
An inch is excessive IMO. Should just cover opening valve.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-parallel & MPPT, Trojan T-125s. TALL flag pole. Prefer USFS, COE, BLM, NPS, TVA, state & county camps. Bicyclist! 14 year Army vet-11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
AJR
Close to Madison Wisconsin
Posted: 10/09/20 06:30pm Link  |  Quote  |  Print  |  Notify Moderator
Never did air only to winterize. The toilet has to have some RV antifreeze in the bowl.
2014 Leprechaun 290QB
Chevy 2400 6.0
2015 GMC Terrain AWD
kellem
Shenandoah valley,VA
Posted: 10/09/20 07:53pm Link  |  Quote  |  Print  |  Notify Moderator
Owned 4 trailers and have not heard of toilet cleaning system.
Make sure everything is pink with RV antifreeze and should be good.
Terryallan
Foothills NC
Posted: 10/09/20 09:22pm Link  |  Quote  |  Print  |  Notify Moderator
bacabunch wrote:
Howdy,
Define toilet drain? Mine just has a straight drop to the black tank. , and yes there will be water in there. If you mean inside the bowl. Open the flapper and let it out, then put some pink in it to keep the seal from drying out
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
bacabunch
Idaho
Posted: 10/10/20 08:22am Link  |  Quote  |  Print  |  Notify Moderator
The cleaning system, hook a hose to the outside hookup and it sprays out the black tank. The water left is in the bottom of the black tank not the bowl. Does the water ever completely drain from the black tank? Im sure im over thinking this but im sure rv antifreeze will just mix with any water residue.....
opnspaces
San Diego Ca
Posted: 10/10/20 08:55am Link  |  Quote  |  Print  |  Notify Moderator
Ah, you're referring to the black tank flush system. Since I don't have to winterize I can't say what I would do. But if you can see the fresh water hose up to the sprayer on the tank I would make sure there's no residual water in it.
As far as the toilet and black and gray tanks. I think based on reading here for many years that most people put a little antifreeze into the waste tanks so that it can flow down to the drain valves and protect them. As far as the tanks as a whole just drain them for winter. The residual liquid in the tanks will freeze. But since the tank is drained there won't be enough ice expansion to damage anything.
In the toilet itself most people pour a little antifreeze to cover the blade seal. Though I've also read about people using mineral oil to cover the blade seal because the pink stuff can stain the plastic bowl.
Bypass and drain the water heater. But do not put antifreeze into it.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
kellem
Posted: 10/10/20 12:16pm Link  |  Quote  |  Print  |  Notify Moderator
Accidentally left black tank half full one winter, no issues simply because there was room for expansion.
A little residual water left in any of the tanks will present no issues.
GrandpaKip
Flat Rock
Posted: 10/11/20 08:05am Link  |  Quote  |  Print  |  Notify Moderator
To winterize the black tank flush, I attach a hose from the outside shower to the inlet. When the system is pressurized, open the shower valve and the pink stuff goes in.
If using air, just switch from city water inlet to the flush inlet.
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
Terryallan
Foothills NC
Posted: 10/12/20 09:46am Link  |  Quote  |  Print  |  Notify Moderator
Honestly. NEVER leave the black tank completely empty, always leave a couple gallons of water in it to keep it from drying out, and causing a septic smell. I leave about 4 gal in mine with tankchem in there.
and there is no need to put antifreeze in there. Freeze damage only occurs when there is no room for the water to expand, once it starts to freeze. If you have 5 gal in a 30 gal tank. There is plenty of room for expansion.
