SM49
ontario
I have a 2004 Four Winds 28 class c, the upper front clearance lights don't work. no power to them, ground is good, all of them work if I feed power to the drivers side light, does anyone know where the wiring would run to feed these lights
Travelin2
SW Florida
They are in the parking light circuit have you checked to see if your chassis parking lights work? If not, I would check the parking light fuse for beginners.
John & Gloria
South West, Florida
1998 Starflyte
Death Valley NP
Has the water resistance been inspected and repaired if necessary?
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-parallel & MPPT, Trojan T-125s. TALL flag pole. Prefer USFS, COE, BLM, NPS, TVA, state & county camps. Bicyclist! 14 year Army vet-11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
SM49
ontario
All other lights work
BFL13
Victoria, BC
They go in sections of pos wire around the top of the Rv. If one light in that section loses its pos wire connection the whole section goes but the other sections work. Pull each light in that section that does not work to find the "open".
edited 10/09/20 06:34pm by BFL13 *
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
SM49
ontario
none of the five front upper lights have power, I used a booster pack to feed that section of lights. the wire that feeds them has no power & I don't know where it comes from
BFL13
Victoria, BC
Ok, say the wire for pos is green like on some. Dowm below there will be a branching of green wires going up to the sections. It seems that branch's wire has come loose down there.
I fixed a problem like that I could not find the right way, by running a wire from the pos of the next section's nearest light to the pos of the dead section's nearest light. So now just one big section. Covered the joining wire up there with white Gorilla tape so it looks fabulous
SM49
ontario
unfortunately I can't find where that wire comes from
BFL13
Victoria, BC
I added the fix I did to previous post.
SM49
ontario
Also there are no other lights close to these ones
