RV.Net Open Roads Forum: What is typical width of class A with side slides both open?
 > What is typical width of class A with side slides both open?
bighatnohorse
Gig Harbor - Cave Creek
Posted: 10/11/20 09:07am Link  |  Quote  |  Print  |  Notify Moderator
Close enough. . .I'd go 15 feet then.
Even if only one slide was open then one could still go inside the RV. Two slides open would probably be "doable".
I have to bring in fill dirt and hire a foundation company to lay the slab - so no squandering allowed.
Thanks all for checking and advisement.
2021 Arctic Fox 1150
'15 F350 6.7 diesel dually long bed
Eagle Cap Owners
“The best lack all conviction, while the worst
Are full of passionate intensity."
-Yeats
Executive
Posted: 10/11/20 09:48am Link  |  Quote  |  Print  |  Notify Moderator
Minimum 6" concrete. Oh! and a walk down pit for maintenance... [emoticon]
...Dennis
We can do more than we think we can, but most do less than we think we do
Dennis and Debi Fourteen Years Full Timing
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
Shot-N-Az
Just South of DC
Posted: 10/11/20 06:22pm Link  |  Quote  |  Print  |  Notify Moderator
I went 16 wide and wish I had gone 18. 16 will accommodate open slides, but it is difficult to walk around the coach, and nearly impossible with the driver’s side living area slide extended.
KCFDCapt
At Home
Posted: 10/12/20 02:30pm Link  |  Quote  |  Print  |  Notify Moderator
I wanted to be able to open my storage compartments when it is inside. I went 20' wide. Yes is costs a little more but the convenience is worth the extra cost.
JRscooby
Indepmo
Posted: 10/12/20 03:02pm Link  |  Quote  |  Print  |  Notify Moderator
...Dennis
Pit is nice when you need to get under, but a PITA any other time.
You drain oil into a pan on the floor, just slide it out. Or move MH away from pan. In a pit? Lift it out without splashing on you.
rk911
DuPage County
Posted: 10/12/20 05:07pm Link  |  Quote  |  Print  |  Notify Moderator
JRscooby wrote:
...Dennis
i guess that would depend on the type of "pan" used. or...you could slide a piece of plywood across the pit to support the pan. or...you could get one of those drain/pans they use at the quickie oil change places. always wanted a garage with a pit.
Rich
Ham Radio, Sport Pilot, Retired 9-1-1 Call Center Administrator
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
