RV.Net Open Roads Forum: Class C Motorhomes: tire pressure class c
 > tire pressure class c
dave17352
Ne
Posted: 10/10/20 07:54pm Link  |  Quote  |  Print  |  Notify Moderator
Just ready to head out in our new to use rig. Its a 2016 260ds Leprechaun. I was checking tire pressure and airing up. Door panel says 65 front 80 rears. I am probably about 13k and the rig has a max of about 14.5. I have not weighed her yet but I have 3k ccc. We are loaded lite. I know things add up quickly as I have had many rigs.
Back to the original question. Assuming I am running well under max what do you folks with a 27 foot class c run your pressures at.
Thanks
Dave
NOW 2017 Leprechaun 260ds
2005 Forrest River Cardinal 29rkle FW
1998 Lance 980 11'3" TC
2017 CHEVY 3500 SRW 6.0
B@W turnover ball @ companion Hitch
Honda eu3000 generator mounted on cargo rack
Crestliner 1850 Fish Ski boat mostly fishing now!
jdc1
Rescue, Ca
Posted: 10/10/20 08:11pm Link  |  Quote  |  Print  |  Notify Moderator
Follow the manufacture's label. They know more about their vehicle than we do.
Camping near Pearsonville, CA
Posted: 10/10/20 08:24pm Link  |  Quote  |  Print  |  Notify Moderator
The C manufacturer knows best.
DrewE
Vermont
Posted: 10/10/20 08:52pm Link  |  Quote  |  Print  |  Notify Moderator
If and when you get actual axle weights for your rig as set up for your use, you can use them. Until then, the door sticker pressures are a reasonable start; they assume the axles are at full gross weight, and you're probably not too far off of that, at least not enough to make a vast difference in the proper tire pressures.
Desert Captain
Tucson
Posted: 10/10/20 08:59pm Link  |  Quote  |  Print  |  Notify Moderator
"Follow the manufacture's label. They know more about their vehicle than we do."
No, they don't,
They have no clue how you will load. The ONLY way to properly inflate your tires is to load the rig as you would for a given trip and take it to the CAT scale. Don't forget to include the weight of your tanks, fresh, gray and black. Keep in mind that your actual weight can vary greatly from trip to trip and while a return to the CAT scale is not essential every time you will have a pretty good handle on what you are actually hauling.{it is probably a lot more than you think}.
Once you know what the rig actually weighs go to the inflation load tables from the manufacturer of your tires and follow those numbers. Blindly following the numbers on the door sticker or worse, inflating to the maximum on the sidewalls is a recipe for disaster.
While most folks leave with empty black and gray tanks not everyone gets to come home that way. Often, on weekends, especially on holiday weekends, the line at the dump station may be hours long. If you choose to drive home with full tanks you have added a lot of extra weight.
some folks run with a full fresh water tank while others assume they can just fill up when they get to the CG, either way that weight {coming/going} needs to be factored into the the load your tires are subject to.
[emoticon]
JIMNLIN
Oklahoma
Posted: 10/10/20 10:18pm Link  |  Quote  |  Print  |  Notify Moderator
we have a class C forum. Ask a mod/adm to move your question over there.
I betcha' you'll get more answers from those who have that size MH.
A tire pressure on the vehicles tire placard is good for a certain weight and a certain tire size/load range. If the tires have been changed to a different size/load range then the placard won't work. Get the units axle weights and use the tire mfg pressure/load charts for best tire pressures.
Posted: 10/11/20 02:07am Link  |  Quote  |  Print  |  Notify Moderator
Aside from “recipe for disaster” Desert Capitan explained the answer to your question perfectly, IMO.
Having a bit more pressure than you need is not major cause for concern. Rougher ride than necessary and a bit less traction in low traction situations, but not inherently unsafe.
Wherever I happen to park
Posted: 10/11/20 04:41am Link  |  Quote  |  Print  |  Notify Moderator
Till you scale it go with the maker's mark (No not the booze) The manfacturer's recommendation.
Then get it weighed and use the Tire Maker's inflation chart.
I say that because there are a few inflation pressures all but guaranteed to be wrong
1: The number on the sidewall (Actually it's right but you need to read the full sentence: Maximum load of xxxxx pounds at maximum pressure of yy PSI)
2: the pressure on the sticker (They do not know know much STUFF you have)
3: The pressure the tire dealer puts in.
On my rig.. turns out the sidewall is correct as loaded.
Home is where I park it.
PartyOf Five
Wheaton, IL
Posted: 10/11/20 06:29am Link  |  Quote  |  Print  |  Notify Moderator
31' C and we run heavy so i load the rears to max, 80 each. The fronts usually at 70 as they seem to handle better than at 65. If it's hot we drive off hours since we can't bring the rear pressures down. If the pavement or weather is poor, we slow down, otherwise we're not too concerned with nominal changes to mileage or handling. Tire age is probably more important to think about.
PartyOf5: Us 2 & 3 pre-teens trying to connect, learn, appreciate creation & the Creator. 5 yrs, 50k
May you find Peace in all that you endeavor
pitch
NY
Posted: 10/11/20 06:59am Link  |  Quote  |  Print  |  Notify Moderator
No, they don't,
[emoticon]
"recipe for disaster" yep we need some drama here![emoticon]
