RV.Net Open Roads Forum: Class C Motorhomes: Lift
Mkewley
Idaho
Posted: 10/10/20 08:49pm Link  |  Quote  |  Print  |  Notify Moderator
So what would be the best way to get the rear end of my class c higher off the ground?
I like to travel off road and done want the back end dragging when going over rougher roads.
Thank you
T18skyguy
Eugene, OR
Posted: 10/10/20 09:25pm Link  |  Quote  |  Print  |  Notify Moderator
I would say airbags. I would make sure you get a good winch too. Many class C's have no good place for a wrecker to hook up to if you get stuck. Some folks weld a hook to the bottom of the frame in case you need it. What kind of rig is it and how rough you want to go?
Retired Anesthetist. LTP. Pilot with mechanic/inspection ratings. Between rigs right now.. Wife and daughter. Four cats which we must obey.
pauldub
North of Seattle
Posted: 10/10/20 10:06pm Link  |  Quote  |  Print  |  Notify Moderator
Taller springs or lift blocks. Airbags will give you a little lift.
pnichols
The Other California
Posted: 10/10/20 11:51pm Link  |  Quote  |  Print  |  Notify Moderator
The best way to lift everything (suspension, transmission, engine, shock mounts, etc.) higher is by installing taller tires.
I did this on our Class C years ago to provide more clearance when we occasionally go on dirt/gravel backroads. Our Class C's chassis is the Ford E450, so it has plenty of extra fender tire well room for tires that our larger in diameter than what came stock on it.
Phil, 2005 E450 Itasca Spirit 24V
Posted: 10/11/20 01:42am Link  |  Quote  |  Print  |  Notify Moderator
Thank you
Loaded question since you didn’t provide hardly any useful or specific info.
Any advice thus far is purely hypothetical since we don’t have enough info to even make a suggestion.
bobndot
Posted: 10/11/20 08:07am Link  |  Quote  |  Print  |  Notify Moderator
I needed more lift to clear my driveway apron and tried air bags. I had to remove them. They only offered 1/2” lift above level. My rv sat level all loaded for a trip. The AB’s will only lift a sagging rear back up to sitting level plus maybe 1/2” as mine did. If 1/2” works for you, then try the AB’s .
Ford E450 25’ 158” WB.
Air Lift was the AB brand.
memtb
Wyoming
Posted: 10/11/20 09:01am Link  |  Quote  |  Print  |  Notify Moderator
pnichols, has “nailed it”! The chassis/frame/body are generally the contact points on irregular terrain.....the only way to address all of these is taller tires!
Awaiting my newish ( on unit when we purchased) tires to wear out or “date expire”.....will be going taller, for sure! memtb
Todd & Marianne
Miniature Schnauzer's - Sundai, Nellie & Maggie Mae
2007 Dodge Ram 3500, 6.7 Cummins, 6 speed manual, 3.73 ratio, 4x4
2004 Teton Grand Freedom, 39'
2007 Bigfoot 30MH26Sl
MDKMDK
Canada
Posted: 10/11/20 09:18am Link  |  Quote  |  Print  |  Notify Moderator
Tow a Wrangler, and use it to "off road". Most class C motorhomes aren't going to like rough roads very much, since they weren't designed for that kind of use. You could do some serious damage to it. Just my opinion.
Mike.
2018 (2017 Sprinter Cab Chassis) Navion24V + 2016 Wrangler JKU (sold @ ????)
2016 Sunstar 26HE, V10, 3V, 6 Speed (sold @ 4600 miles)
2002 Roadtrek C190P (sold @ 315,000kms)
jdc1
Rescue, Ca
Posted: 10/11/20 09:25am Link  |  Quote  |  Print  |  Notify Moderator
Taller tires and a real lift kit (all 4 corners). The lift kit would include front springs, rear leafs, longer shocks and any necessary front suspension parts.
Posted: 10/11/20 10:33am Link  |  Quote  |  Print  |  Notify Moderator
^What he said.
And also not practical for a C chassis. As in expense.
Can’t shove a square peg thru a round hole.
But you could do or buy a 4wd conversion, again, what are you willing to pay?
