RV.Net Open Roads Forum: General RVing Issues: HELP! Black tank spill inside
 > HELP! Black tank spill inside
Goldgrits
Washington
Posted: 10/11/20 07:50am Link  |  Quote  |  Print  |  Notify Moderator
Two days ago I overflowed the toilet on my small black water tank on the second flush of the tank. Water was mostly clean but still black water. I cleaned and sanitized everything I could see.
I took off a panel in the kitchen wall and have noticed moisture under the plastic sheeting that is behind the toilet and under the kitchen area.
How do I get to the rest of the moisture to clean.
The motor home was not level so the flow went from the middle located toilet through the kitchen area then out the drivers side front. Only two basement areas has moisture.
Help help help. New 2018 Winnebago.
Goldgrits is online now
Cross posted in in Irv2
otrfun
On The Road
Posted: 10/11/20 08:13am Link  |  Quote  |  Print  |  Notify Moderator
In addition to manually drying everything the best you can, I'd suggest using a high-velocity, squirrel cage fan to air out the moist areas as much as possible---especially the basement area.
Camping near Pearsonville, CA
Posted: 10/11/20 08:25am Link  |  Quote  |  Print  |  Notify Moderator
X2. The more fans the better. Open up walls, floors as best you can.
Goldgrits
Washington
Posted: 10/11/20 08:47am Link  |  Quote  |  Print  |  Notify Moderator
Thanks. I’ve been running two large humidifiers with the lower cabinet open and am running a small fan in the basements
d3500ram
Colorado
Posted: 10/11/20 08:59am Link  |  Quote  |  Print  |  Notify Moderator
I tend to take things literally...Did you mean to say "DE-humidifiers?"
ajriding
st clair
Posted: 10/11/20 09:36am Link  |  Quote  |  Print  |  Notify Moderator
short of taking things apart the fan should do it. If you have carpet I would pull it up and clean under, or at least do some heavy repeated steam cleaning. You can rent steam cleaners at a u-haul or some grocery stores also.
You won't be able to get behind the walls, but as long as it dries out and stays dry that grossness should not be an issue in the dry future.
Goldgrits
Washington
Posted: 10/11/20 09:48am Link  |  Quote  |  Print  |  Notify Moderator
Thanks. I'm worried about toxins and my grandkids.
Seon
Lake Camanche, CA
Posted: 10/11/20 10:16am Link  |  Quote  |  Print  |  Notify Moderator
Electric leaf blower to blow excess water from under the toilet and cabinet then the fans.
doxiemom11
Paris Michigan
Posted: 10/11/20 01:41pm Link  |  Quote  |  Print  |  Notify Moderator
Air conditioner will remove moisture from the air and help dry things out too. I'd run the air with fans blowing.
ajriding
st clair
Posted: 10/11/20 02:25pm Link  |  Quote  |  Print  |  Notify Moderator
it's just a little poo. Other than initial smell there should not be a lot of contamination unless the tank had been full for a long time. There could be bad bacteria, but that would come from a gross tank not from your colon.
Once it dries then anything that lived in it will die also.
It sounds gross, but will not be a health hazard. Some disinfectant will not be a bad idea to spray while it is still wet.
