RV.Net Open Roads Forum: Fifth-Wheels: NEVER TO OLD TO LEARN (new tricks)
 > NEVER TO OLD TO LEARN (new tricks)
GPG52!
BURLINGTON, ON
Posted: 10/12/20 09:05am Link  |  Quote  |  Print  |  Notify Moderator
I have a couple of RV winterizing questions:
QUESTIONS:
.. - What is the optimum PSI used when blowing out your RV water lines? (Newer trailers using PEX piping)
..- Do you disconnect your LP gas tanks before winter storage? After you securely close your LP tank valves, do you disconnect the tanks to relieve pressure in your RV's gas lines.
CURIOUSITY:
..- More of a preference on my part... Do you remove your spare tire cover and store it indoors vs. leaving it out to the elements for the winter months...con's leaves the spare tire open to elements and possible premature weather damage.
GPG ">
2014 Ford F250, 6.2L, 4.30 Ratio, 6 speed
2014 Cougar (by Keystone) 327 RES
BurbMan
Islip, Long Island
Posted: 10/12/20 09:15am Link  |  Quote  |  Print  |  Notify Moderator
I would stay around 40-45 psi, that's where a regulator keeps you when connected to city water. Don't forget to open the low point drains and relieve the pressure on the check valve.
I leave my propane connected and on year-round. I am usually in the RV during the off-season making mods of some kind and sometimes it's nice to have heat on.
The cover protects the tire primarily from UV damage which is just as bad in the winter as summer. If you're parked in such a way that the spare stays out of the sun all day, then it wouldn't hurt to bring the cover inside. If your spare gets any sun at all, I would leave the cover on it.
Also remember to prop open the fridge doors when it's turned off to prevent mold and mildew.
SOLD: 2008 Terry 34' TT
SOLD: 2001 K2500LT 8.1L Suburban
Lance 811 Renovation Story!
Project Complete!
Maiden Voyage!
Terryallan
Foothills NC
Posted: 10/12/20 09:49am Link  |  Quote  |  Print  |  Notify Moderator
I remove my spare tire and lay it inside the camper. It's clean, and hurts nothing. Ain't heavy either.
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
valhalla360
No paticular place.
Posted: 10/12/20 10:10am Link  |  Quote  |  Print  |  Notify Moderator
If you set the air pressure about the same as the city water pressure regulator, it shouldn't hurt anything.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Full Time spliting time between boat and 5er
GPG52!
BURLINGTON, ON
Posted: 10/12/20 10:15am Link  |  Quote  |  Print  |  Notify Moderator
Thank you to all..
BurbMan, when you say "relieve the pressure on the check valve" are you referring to the Hot Water Tank check valve?
Terryallan
Foothills NC
Posted: 10/12/20 07:58pm Link  |  Quote  |  Print  |  Notify Moderator
GPG52! wrote:
Thank you to all..
just open a valve / faucet any where. It will let the pressure off the system
time2roll
Posted: 10/12/20 08:09pm Link  |  Quote  |  Print  |  Notify Moderator
LP - Turn off the main valve at the cylinder only.
Tire Cover - Blew off en route a decade ago and never replaced.
675w Solar pictures back up
cummins2014
Utah
Posted: 10/13/20 04:02pm Link  |  Quote  |  Print  |  Notify Moderator
IMO I wouldn’t use compressed air , unless you have filtration system on your compressor. There is no way I want what I see draining out of mine going into those water lines .
Limit4
Festus Missouri USA
Posted: 10/15/20 07:58am Link  |  Quote  |  Print  |  Notify Moderator
Just on the tire cover, being a 5 or 6 times a year camper and usually for 2 weeks or less, I remove my cover before I leave and put it on when I return home. I have lost 2 when traveling.
Dave H M
IL
Posted: 10/15/20 08:13am Link  |  Quote  |  Print  |  Notify Moderator
Excellent point there cummins [emoticon]
