RV.Net Open Roads Forum: Beginning RVing: Problems unique to Toy Haulers
 > Problems unique to Toy Haulers
CFerguson
on the road
Posted: 10/12/20 01:26pm Link  |  Quote  |  Print  |  Notify Moderator
We've never had a TH, but have been thinking of adding one to the fleet. Any issues/considerations specific to Toy Haulers that i should look out for? (prob looking at a shorter TT or 5er.)
JAC1982
Colorado
Posted: 10/12/20 02:13pm Link  |  Quote  |  Print  |  Notify Moderator
We've had 2 toyhaulers, both a TT and 5th wheel and now have a traditional 5th wheel. I can't think of anything that is unique to a toyhauler. Just make sure your truck is big enough to pull it, as they typically are heavier.
2020 Keystone Montana High Country 294RL
2017 Ford F350 DRW King Ranch
2021 Ford F350 SRW Lariat Tremor
cliffy49
Blue Grass
Posted: 10/12/20 02:19pm Link  |  Quote  |  Print  |  Notify Moderator
The only thing I can think of is that a toy hauler will usually have a heavy tongue weight as comapred to a normal trailer. This is for the weight of the toy you nay have in it. My Catalina has a dry tongue weight of 957 lbs. but has come down to 825 with my harley loaded.
cliffy49
2016 F150 Ecoboost & max tow (Gone)
2021 Silverado Custom 2500HD
2018 Catalina TH26 Toy hauler
SAR Tracker
Central Oregon
Posted: 10/12/20 04:53pm Link  |  Quote  |  Print  |  Notify Moderator
Fresh water: get a model that has a fresh water dump valve. Or install one. Otherwise, you have to empty thru the sink, into a gray tank, then out the pooper pipe.
Gas tank / station: Ensure your gas station / generator fuel pickup is near the bottom of the tank. Otherwise, one or the other will run out.
Rusty & Cheryl
2011 F250 2WD 6.2L Gasser
2008 Weekend Warrior FB2100
"Common sense is in spite of, not the result of, education" - Victor Hugo (1802-1885)
ORbiker
Springfield, Oregon
Posted: 10/12/20 09:23pm Link  |  Quote  |  Print  |  Notify Moderator
What toy are you going to haul?
Do you want a separate garage from your living space?
We have a very big 5th wheel, with a smaller garage. KEN
Backpacker and tent camper all my life. Motorcycle trips with a tent too 1978 to Present. 2016 Grand Design 380TH as of 10-29-2015. Now a New 2018 374TH-R Solitude as of 3-16-19. 10-19-18-traded truck for a 2016 Ram 3500 DRW Laramie Crew Cab 4x4 Long Box.
Megadesertdiesel
Aizona
Posted: 10/13/20 06:43am Link  |  Quote  |  Print  |  Notify Moderator
wall sag is a toyhauler issue. No interior perpendicular walls to support the cabinets and heavy fiberglass siding. Lippert only puts so many frame out riggers to support the walls and usually between the wheel wells the sagging is the worst.
everything coming loose due to rougher roads taken to get to trails, have to stay on top of al the little things.
CFerguson
on the road
Posted: 10/13/20 10:24am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the replies, folks!
At the moment, my toys only consist of bicycles and kayaks. But a dirt bike or a 4wheeler (a pair of Rokons is just a thought at this point) is a possible future add. Nothing particularly heavy, just enough to offroad a bit in western deserts for rock hounding. No plans to treat the space as a garage once we park- we intend to secure the toys outside and use the space as living area. And i definitely watch weights/towing capabilities.
slider45
GA
Posted: 10/21/20 09:25pm Link  |  Quote  |  Print  |  Notify Moderator
Definitely prefer one with fresh water. A neighbor had a some hard time with water access on their last TH.
