RV.Net Open Roads Forum: Class A Motorhomes: Thor Axis 24.1
 > Thor Axis 24.1
A1ARealtorRick
Gulf Shores, AL
Posted: 10/17/20 09:42am Link  |  Quote  |  Print  |  Notify Moderator
Gjac wrote:
way2roll wrote:
A1ARealtorRick wrote:
"......but also have a lower tow rating (18,500 combined vs 22,000 combined)"
But unless you have a Sherman tank as a toad, for most the difference in tow rating is probably a non-issue [emoticon]
I was surprised at the 2020 specs for capacity on such a small coach. Depending on the model there is between 6-7.5k lbs of actual towing capacity. Impressive for such a small coach - or maybe it's because it's a small coach. There are a LOT of larger gassers with almost no capacity left.
You are right my current 33 ft Class A can't tow that much. When I compare specs against other Class A's or space against small Class C's. HP/wt ratio, WB/L ratio all look impressive. The only concern is the quality of Thor products. That is why I asked if any on here actually own one, but not one owner has responded yet.
That's because they're outside fixing their RV [emoticon]
. . . never confuse education with intelligence
way2roll
Wilmington NC
Posted: 10/17/20 10:42am Link  |  Quote  |  Print  |  Notify Moderator
I've seen Axis/Vegas owners respond here and most were very positive. Some complaints about the location of the chassis batteries but don't remember anyone saying anything major. You may want to check the Thor forums. We had an ACE before our current FW and it was trouble free for the 5 years we owned it. Fit and finish was low end but that was to be expected for what we paid. We loved it, but we are going to be travelling more extensively and wanted something that was better to part time in.
2020 FR Cedar Ridge Silverback 29rw
Gjac
Milford, CT
Posted: 10/17/20 11:00am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the feed back. It is hard to tell how bad a product is based on the number off complaints. I think by far Thor produces more RV's than Winnebago, Tiffin etc. So based on shear number of units produced I would expect more complaints from a company that produces more units over a company that produces lesser units. What would be a better metric is issues/ x number of units produced.
rjstractor
Maple Valley, WA
Posted: 10/17/20 07:30pm Link  |  Quote  |  Print  |  Notify Moderator
way2roll wrote:
The Axis/Vegas is an RUV - which is a fancy way to market a C and A hybrid. They are built on the e350 or E450 Chassis - depending on which year it was manufactured. So they aren't a true Class A. They were marketed as a way to take kids to soccer games, travelling sports families, tailgating that sort of thing. I've owned a Thor Class A (an ACE) and while we knew what we were buying, I must admit that quality is about the lowest in the industry. But so are their prices. If you have realistic expectations then you might be OK, but buyer beware. The sprinters you are looking at are Mercedes chassis so there is a reason they cost more and you are comparing oranges to basketballs comparing it to a Vegas. A Class B Plus or small C on a Mercedes chassis is going to be so much easier and quieter to drive and your mileage will be much better as well. Nothing wrong with the Vegas/Axis if that's what you want and have realistic expectations but there isn't much comparison to that and something on a Sprinter chassis with a diesel engine.
How does that make it not a Class A? It's built on a bare chassis with no factory cab or body. I understand the chassis is the same as that of an E350 or 450, but without the factory cab by definition it's a Class A.
A1ARealtorRick
Gulf Shores, AL
Posted: 10/18/20 05:33am Link  |  Quote  |  Print  |  Notify Moderator
You are correct -- they are Class A's. Class C's are built on cutaway chassis' and CLass B's are van cutaway's or solid boxes. Thor can call it an RUV if they want to, trying to create a new class and broaden the appeal, but it is a true Class A.
Gjac
Milford, CT
Posted: 10/20/20 06:47am Link  |  Quote  |  Print  |  Notify Moderator
As I noted in my OP it looked difficult to access the engine because the dog house was so small. I wanted to go back and see what the access was like with the dog house removed. It only had about 4 screws to remove cover. The salesmen called me back and said the techs at the dealership would not allow the cover to come off. I thought that strange and of course only reinforced my belief of the difficulty of changing spark plugs or adding water to the battery. Was my request unreasonable?
way2roll
Wilmington NC
Posted: 10/20/20 08:51am Link  |  Quote  |  Print  |  Notify Moderator
Nope, not unreasonable and good for you. That is one of the issues I saw noted in some reviews, the inability to access the batteries etc. It was one of the few complaints I remember seeing, but a consistent one.
On edit - that's also a dealership I would avoid. Not allowing you to look under the hood/doghouse of an RV you are considering buying is ridiculous. Did they say why?
* This post was edited 10/20/20 09:52am by way2roll *
carringb
Corvallis, OR
Posted: 10/20/20 09:13am Link  |  Quote  |  Print  |  Notify Moderator
Well, if you decide to proceed, maybe make your offer contingent on a maintenance contract that includes spark plugs, spark plug wires, and batteries for the first 5 years?
Bryan
2014 ORV really big trailer
2015 Ford Focus ST
JRscooby
Indepmo
Posted: 10/20/20 10:28am Link  |  Quote  |  Print  |  Notify Moderator
Doubt the RV would run enough in 5 years to need plugs. OEM battery is good for 6
warrenjo46
Matthews, NC
Posted: 10/20/20 07:36pm Link  |  Quote  |  Print  |  Notify Moderator
OK, now you did it. I owned a 2015 Vegas 24.1 for two years and really liked it. I don't understand the comments about Thor quality unless I was just lucky. I can not complain about the quality a bit.
the OP is correct about working on the engine. I had to replace the battery and it took me half a day to get it done. However, I think that motor homes are generally compact and that makes repair and replace more difficult.
 > Thor Axis 24.1
