kellem
Shenandoah valley,VA
Hmmm been using a DC for 15 years without a single issue.
Was it set up properly, set up level?
How many chain links used for towing ?
Was trunnion bar pulled up all the way up to cam ? 5 or less links of chain?
Arn
Ottawa Valley, Ontario, Canada
Been using this one for 10 years. Had it recently set up for my new truck by a hitch shop & have towed all summer with no issues. Towed level at 6 links, cams were properly seated in the bar detents & FALR was 100%. No marks on "A" frame so there was no contact. The threaded part of the cam bent up which to me defies the laws of physics because the bar is pulling down on the cam.
edited 10/14/20 08:55am by Arn *
Arn
1958 Me
1963 Her
2015 Jayco Jay Flight 33RLDS
2020 Silverado LTZ Crew, 5.3 Max Trailering Pkg.
BarneyS
S.E. Lower Michigan
Looks to me like the cam arm may have bottomed out on a driveway dip/rise, rock, or some other hard surface. If only on one side then it could have occured while turning.
In the 2nd picture, it looks to me like the cam lifting bracket was put on backwards. The nuts should be on the outside of the bracket and the chain on the inside. It is very easy to put it on backwards and it will work that way BUT there is the chance the lifting bracket will be bent because of the chain pull on it - resulting in it looking like yours.
Barney
last
edited 10/14/20 12:26pm by BarneyS *
View edit history
Not towing now.
Former tow vehicles were 2016 Ram 2500 CTD, 2002 Ford F250, 7.3 PSD, 1997 Ram 2500 5.9 gas engine
Arn
Bracket was on correctly & I don't recall bottoming out. Certainly possible though. I'll check the bottom of the cam & the tip of the bar for scuff marks.
kellem
After a 2nd look, still can't imagine the culprit other than bottoming out in reverse or possibly an extremely sharp turn where the trunnion was close to being ejected and apon straightening back up.....the top section of trunnion caught the cam bracket.
Inspect the tip of trunnion for gouge marks.
Oh, 6 links does seem to be the sweet spot with these hitches.
Arn
Checked the tip of the trunnion bar & the bottom of the cam & there is no damage beyond what is in the pictures. I'm almost afraid to stick with the Dual Cam setup. I'm in Canada so it's $500 just for the Reese 26002 kit which is only cams, hangar brackets & chains. If I go with that & the same thing happens then I just spent good money after bad. Blue Ox will run me around $1,000 & haven't yet priced Equalizer. What to do, what to do...
mosseater
Dillsburg, PA
Do you have pix of the set up hitched on the tv before things went wrong?
Sunset Creek 298 BH
Arn
mosseater wrote: Do you have pix of the set up hitched on the tv before things went wrong?
It's from quite a distance but does show the set up.
![[image]](https://i.imgur.com/KFZ8Sjal.jpg )
Click For Full-Size Image.
lane hog
Tucson, AZ & NW Chicago Burbs, IL
I've used the dual-cam on and off for 15 years. Reese is serious about their warranty, so I'd suggest calling them. They sent me replacement parts when I had an issue back in 2006.
- 2019 Grand Design 29TBS (had a Winnebago and 3x Jayco owner)
- 2016 F-150 3.5L MaxTow (had Ram 2500 CTD, Dodge Durango)
- 130W solar and 2005 Honda EU2000i twins that just won't quit
mosseater
Dillsburg, PA
That's pretty far away. Looks like it's a bottom coupler, so clearance usually isn't a problem. Hmmm....
