RV.Net Open Roads Forum: Fifth-Wheels: No more Bridgestone Duravis R250 tire?
 > No more Bridgestone Duravis R250 tire?
N-Trouble
NorCal
Posted: 10/12/20 04:15pm Link  |  Quote  |  Print  |  Notify Moderator
I lost one this past weekend (bad blowout) and am looking to replace and see its no longer listed on Bridgestone's website. Does anyone know if the R238 is a replacement for the R250?
2015 Attitude 28SAG w/slide
2012 GMC 2500HD SLT Duramax
B&W Turnover w/Andersen Ultimate 5er hitch
Me Again
Sunbird(Wa)/snowbird(Az)
Posted: 10/12/20 04:21pm Link  |  Quote  |  Print  |  Notify Moderator
Yes! Pictures of the failed tire? I find it hard to believe a R250 has a sudden blow out. How old were they?
2021 F150 2.7 Ecoboost - Summer Home 2017 Bighorn 3575el. Can Am Spyder RT-L Chrome, Kawasaki KRX1000. Retired and enjoying it!
N-Trouble
NorCal
Posted: 10/12/20 04:38pm Link  |  Quote  |  Print  |  Notify Moderator
Its not pretty...
N-Trouble
NorCal
Posted: 10/12/20 04:41pm Link  |  Quote  |  Print  |  Notify Moderator
N-Trouble
NorCal
Posted: 10/12/20 04:48pm Link  |  Quote  |  Print  |  Notify Moderator
Tires are 2-3yr old. Spare measures 12mm tread depth and my running tires are all at 10-11mm with even wear across all tires. They dont sit in the sun and have zero cracks.
Now to the day it blew I was only traveling 63-65mph (do 70+ all the time in NV) and had only been on the highway for 30-40min when it let go. I felt it blow and pulled off immediately. The entire tread ring was still intact and separated from the tire. Trailer is only 12klb GVWR so tires were not run up at their limits. Run them all at 70psi all the time. Go figure...
gbopp
The Keystone State
Posted: 10/12/20 05:24pm Link  |  Quote  |  Print  |  Notify Moderator
That wasn't a blowout. It was a Nuclear Detonation. [emoticon]
jaycocamprs
Ringgold Georgia
Posted: 10/12/20 05:29pm Link  |  Quote  |  Print  |  Notify Moderator
Yes the R-238 is Bridgestones replacement for the R-250. You must have either got some of the last ones made, or some that sat in some warehouse. 2018 was when I replaced the ones I had, the R-238 was out then. I got 5 trouble free years on a 12K trailer, 2800/2900 on pin. Replaced with Sailun S637s.
2018 Silverado 3500 DRW
2011 Montana Mountaineer 285RLD
N-Trouble
NorCal
Posted: 10/12/20 06:21pm Link  |  Quote  |  Print  |  Notify Moderator
It sure felt like it. I think I'm lucky I got away with no damage to the undercarriage/side of trailer.
Me Again
Posted: 10/12/20 11:08pm Link  |  Quote  |  Print  |  Notify Moderator
I think a tire engineer like Roger would stay that tire was run flat, as in it picked up a nail or something else. Also the remaining tire on that side should also be replaced, as it could have been over loaded longer than you think.
"I felt it blow and pulled off immediately." a tire that has a sudden failure is not going to look like it has travel for miles on a highway in a flat condition.
N-Trouble
NorCal
Posted: 10/13/20 08:21am Link  |  Quote  |  Print  |  Notify Moderator
Agree with what your saying. All I can say is one second I was running fine, next second there was a pretty violent tug from the trailer on the truck. Looked out the passenger side mirror and saw chunks of rubber flying. I was running solo so had nobody behind me when it happened. Lonely stretch of HWY 395 just north of Ridgecrest.
