RV.Net Open Roads Forum: Travel Trailers: Andersen hitch doesn't suit, any other recommendations?
 > Andersen hitch doesn't suit, any other recommendations?
Prior Pete
McNab, Ontario
Posted: 10/12/20 08:21pm Link  |  Quote  |  Print  |  Notify Moderator
Time to replace my old WD hitch. I'm towing an 8,500lb 36' trailer with about 1,100lb tongue weight. Any experience with Andersen No Sway hitches? It sounds like it might be just what I'm after. Any info would be appreciated. Thanks.
Edit: Seems I have too much tongue weight for Andersen to work well. Looking for recommendations.
* This post was last edited 10/13/20 07:10pm by Prior Pete *   View edit history
rexlion
Broken Arrow OK
Posted: 10/12/20 09:24pm Link  |  Quote  |  Print  |  Notify Moderator
Some years back a good thread on the subject revealed that when going above 700 or so lbs of tongue weight the Andersen didn’t have enough leverage to level the rig. I used one for a couple years with a 2700 lb (350 hitch wt) TT and liked it (but it sold with the TT).
Mike G.
--for now, using a cargo trailer for camping--
Those who would give up essential liberty, to purchase a little temporary safety, deserve neither liberty nor safety. --Benjamin Franklin
photo: Yosemite Valley view from Taft Point
TomG2
Central Illinois
Posted: 10/13/20 06:52am Link  |  Quote  |  Print  |  Notify Moderator
You are probably one of those people who do not get to use an Andersen hitch. Too much tongue weight for it to handle well. The hitch works very well for smaller trailers towed with adequate tow vehicles.
GrandpaKip
Flat Rock
Posted: 10/13/20 07:56am Link  |  Quote  |  Print  |  Notify Moderator
I have 600# of tongue weight on an Andersen and wouldn’t go much higher. 1000# probably too much.
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
goducks10
There
Posted: 10/13/20 09:03am Link  |  Quote  |  Print  |  Notify Moderator
Depends on what you're towing with. I used one for a short period of time before getting a 5th wheel. I used it with a 2500 Cummins and a 900-950 lb TW TT. Worked great because I didn't need to return much weight back to the front of the truck being that the Cummins is way heavier than a gas motor. Front hardly lifted when hitched.
I previously towed the same TT with an F150 and needed 1200 lb bars to restore the front of the truck.
My thinking is I could've never made the Andersen work with the F150 but it was great with the 2500 CTD since it didn't need to transfer as much weight and the truck wasn't softly sprung like a 1/2 ton is.
Like mentioned above it seemed when they 1st came out and there were lots of trials with them that the heavier the TW and the lighter duty the truck the harder it was to make the Andersen work.
On a good note, it's a really nice looking hitch. [emoticon]
Ron3rd
Upland, CA USA
Posted: 10/13/20 03:41pm Link  |  Quote  |  Print  |  Notify Moderator
The Anderson has its application for lighter trailers but would be a poor choice for your trailer imo
2016 6.7 CTD 2500 BIG HORN MEGA CAB
2013 Forest River 3001W Windjammer
Equilizer Hitch
Honda EU2000
Prior Pete
McNab, Ontario
Posted: 10/13/20 04:27pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks folks, sounds like Andersen is out. Now I'll look for recommendations. Equalizer? Dual Cam? Blue Ox? Others? Oh ya, towing with 2020 Silverado, crew cab, 6'5" box & max trailering package.
afidel
Cleveland
Posted: 10/13/20 10:31pm Link  |  Quote  |  Print  |  Notify Moderator
Any of the 3 you mentioned will do well, they're all available in appropriate weight ratings and pretty well regarded. The one thing I'll note is that the Equalizer head is not able to accommodate different weight bars so if there's a chance you'll downsize in the future keep that in mind (though honestly it's more of a consideration for those that are likely to move up in the future, I think a much smaller percentage of owners downsize significantly)
2019 Dutchman Kodiak 293RLSL
2015 GMC 1500 Sierra 4x4 5.3 3.42 long bed
Equalizer 10k WDH
fx2tom
CA
Posted: 10/14/20 09:42am Link  |  Quote  |  Print  |  Notify Moderator
I LOVE the Equal-I-Zer hitch. Towed a 36 foot 8300 lb travel trailer with it for 6 years without a single issue. Easy to use and does a great job handling weight and sway. Short of going Hensley I wouldn't go with anything else for my use.
2002 Ford F250 Lariat 7.3l 4x4 CCSB
2007 Forest River Sierra Sport M-26FBSP
lane hog
Tucson, AZ & NW Chicago Burbs, IL
Posted: 10/15/20 06:13am Link  |  Quote  |  Print  |  Notify Moderator
I've been using a Reese Dual-Cam on and off for 15 years. Love it, wouldn't be without it.
  • 2019 Grand Design 29TBS (had a Winnebago and 3x Jayco owner)
  • 2016 F-150 3.5L MaxTow (had Ram 2500 CTD, Dodge Durango)
  • 130W solar and 2005 Honda EU2000i twins that just won't quit
