RV.Net Open Roads Forum: California DL towing an Exactly 10,000 lb GVWR trailer
 > California DL towing an Exactly 10,000 lb GVWR trailer
jthrv
Los Angeles
Posted: 10/13/20 08:29am Link  |  Quote  |  Print  |  Notify Moderator
Can I tow an Exactly 10,000 lb GVWR trailer ?
The DMV Handbook says No, as it has to be "under 10,000".
The Vehicle Code says Yes, as it is "Not exceeding 10,000".
Why would they be different ?
DMV Handbook, Page 9 https://www.dmv.ca.gov/portal/uploads/2020/06/dl600.pdf
Class C DL - ...."With a vehicle weighing 4,000 lbs. or more unladen, you may tow a: — Trailer coach or fifth-wheel travel trailer under 10,000 lbs. GVWR when towing is not for compensation."
Section 12804.9 of the Vehicle Code https://leginfo.legislature.ca.gov/faces/codes_displaySection.xhtml?sectionNum=12804.9&lawCode=VEH#
(3) Class C ... (F) (i) "A two-axle vehicle weighing 4,000 pounds or more unladen when towing either a trailer coach or a fifth-wheel travel trailer not exceeding 10,000 pounds gross vehicle weight rating, when the towing of the trailer is not for compensation."
(edited to fix url)
* This post was edited 10/14/20 03:48am by jthrv *
DrewE
Vermont
Posted: 10/13/20 08:45am Link  |  Quote  |  Print  |  Notify Moderator
The vehicle code is law. The DMV handbook is not law, just a (mostly) authoritative informational publication. If you are cited for not having the correct license and go before a judge, the vehicle code is what the decision will be based on.
As an aside, I'm rather surprised that they codified it based on the GVWR rather than the actual weight, but that's not really relevant to the question.
RoyF
Fayetteville Arkansas
Posted: 10/13/20 08:56am Link  |  Quote  |  Print  |  Notify Moderator
The online DMV handbook contains the following disclaimer:
"The state makes no claims, promises, or guarantees about the absolute accuracy, completeness, or adequacy of the contents of this website and expressly disclaims liability for errors and omissions in the contents of this website."
So the vehicle code should hold up in court. This is an amusing exercise for lawyers.
It seems to be OK to overload a trailer if the weight rating is less than 10,000 lbs.
Old-Biscuit
Verde Valley
Posted: 10/13/20 09:32am Link  |  Quote  |  Print  |  Notify Moderator
You can tow 10K or Under with your Class C Drivers License
You can NOT tow a 10,001# with your Class C DL
SIMPLE....
Posted: 10/13/20 10:38am Link  |  Quote  |  Print  |  Notify Moderator
It’s a good question and the “rules” are contradictory in other states as well.
Many say “under 10k” when they really should say under 10.001k or “over” 10k.
Don’t sweat it. It’s the 10klb law which is a federal DOT standard.
If it wasn’t, the “standard “ 3/4 tons would be rated 9999lb gvw and same with trailers.
(Yes I realize there are many class 2 trucks now rated over 10klbs as well in recent years. )
wgriswold
Lake Tahoe
Posted: 10/13/20 12:46pm Link  |  Quote  |  Print  |  Notify Moderator
The Handbook also states for a regular class C license:
If the towing vehicle weighs 4,000 lbs. or more unladen, you may tow a:
Trailer coach not exceeding 9,000 lbs. gross.
I suppose the law says the same thing but don't know how to check that.
2016 Ram 2500 4x4 Laramie
Arctic Fox 25Y
Alan_Hepburn
San Jose, Ca, USA
Posted: 10/13/20 02:40pm Link  |  Quote  |  Print  |  Notify Moderator
By specifying GVWR it can be checked during a traffic stop by simply reading the data placard on the vehicle; if it were codified as actual weight then all stops would require a scale to be available in order to determine the actual weight.
Alan & Sandy Hepburn driving a 2007 Fleetwood Bounder 35E on a Workhorse chassis - Proud to be a Blue Star Family!
Good Sam Member #566004
jthrv
Los Angeles
Posted: 10/13/20 03:18pm Link  |  Quote  |  Print  |  Notify Moderator
"(B) Notwithstanding subparagraph (A), a two-axle vehicle weighing 4,000 pounds or more unladen when towing a trailer coach not exceeding 9,000 pounds gross."
Maybe this url will work better:
Second Chance
Wherever...
Posted: 10/13/20 05:46pm Link  |  Quote  |  Print  |  Notify Moderator
Made your link clickable: Click
U.S. Army retired
2020 Solitude 310GK-R
2012 F350 CC DRW Lariat 6.7
Full-time since 8/2015
Posted: 10/13/20 06:17pm Link  |  Quote  |  Print  |  Notify Moderator
So Cali has a 9k towing law, not 10 like the rest of the world?
To be specific 10k trailer is not a limit for non commercial driving most other places either.
Just over 10k Truck commercially requires DOT numbers and drivers file. Combo under 26k = no cdl.
