RV.Net Open Roads Forum: Dogde 1978 class c water leaking underflow
 > Dogde 1978 class c water leaking underflow
Santaflow
Eureka
Posted: 10/14/20 12:33am Link  |  Quote  |  Print  |  Notify Moderator
Hello,
Im traveling with that machine.
I'm handling a wattering problem from the water pump pipes to the sink. I dont know how to access to the pipes underfloor.
Better to remove carpet and wood or going undercar?.
Thanks in advance for the help.
gbopp
The Keystone State
Posted: 10/14/20 04:38am Link  |  Quote  |  Print  |  Notify Moderator
Santaflow wrote:
I'm handling a wattering problem from the water pump pipes to the sink. .
Are you talking about a leak or are you not getting water to the sink?
Santaflow
Eureka
Posted: 10/14/20 01:29pm Link  |  Quote  |  Print  |  Notify Moderator
Hello,
It’s both, I get water but with not much pressure and the floor gets wet and also the car leaks underfloor.
Thanks.
gbopp
The Keystone State
Posted: 10/14/20 03:40pm Link  |  Quote  |  Print  |  Notify Moderator
Do you have low flow from the hot or cold side of your faucet, or both sides?
Did you unscrew the end of the faucet where the water comes out and clean the screen?
Did you look under the sink while the water is running to look for leaks?
Santaflow
Eureka
Posted: 10/16/20 05:21am Link  |  Quote  |  Print  |  Notify Moderator
Hello,
I checked under the sink and the pipes from there to underfloor are ok. Also the pipes from the water pump to underfloor are also ok.
The car is a big sur 225. There is any way to know the planes of the chasis?? So I can know how to access to the plumbing.
Thanks
