RV.Net Open Roads Forum: General RVing Issues: Preferrred Water Heater
 > Preferrred Water Heater
RobWNY
Jamestown, NY
Posted: 10/14/20 07:26am Link  |  Quote  |  Print  |  Notify Moderator
Which brand water heater do you prefer? I've had both the steel Suburban and the aluminum Atwood/Dometic. They are both excellent water heaters. Personally, I prefer the Atwood/Dometic but which do you prefer?
2020 Silverado 2500HD LT, CC, 4X4 6.6 Duramax
2021 Grand Design Reflection 311BHS
You can't put a porcupine in a barn, set it on fire, and expect to make licorice.
goducks10
There
Posted: 10/14/20 08:22am Link  |  Quote  |  Print  |  Notify Moderator
https://truma.net/water-systems 1st choice
But I've never had an issue with my current and previous Suburban's
Lynnmor
Red Lion
Posted: 10/14/20 08:30am Link  |  Quote  |  Print  |  Notify Moderator
Depends on your preference; anode rods or soft plastic drain plugs.
Old-Biscuit
Verde Valley
Posted: 10/14/20 09:34am Link  |  Quote  |  Print  |  Notify Moderator
Both have pros/cons
Suburban
PROs
Major components are accessible via outside compartment (Both sets of T-stats, gas valve, electric element, anode rod)
CONs
AC & DC Junction Boxes on backside along with circuit board which does not have a Fuse and combustion/exhaust 'U' Tube is stacked so unequal surface contact for heat transfer, Steel glass-lined tank which can not be replaced, NO air shuttle to adjust air/fuel ratio
Atwood
PROs
Aluminum Tank/no anode rod, gas valve accessible, thermal fuse protection, air shutter, diagonal combustion/exhaust 'U' Tube for better heat transfer, Fuse protected circuit board, NYLON Hi Temp/Press drain plug, replacement tanks available
CONs
Only one set of t-stats for both AC/Gas operation, DC Relay and AC Element on backside of WH Tank
Both Brands are functional, do what they were designed to do and are roughly equal in easy of use
For me it's a toss up
Whichever one comes in the RV I purchase is fine!
RobWNY
Jamestown, NY
Posted: 10/14/20 11:13am Link  |  Quote  |  Print  |  Notify Moderator
Old-Biscuit wrote:
Atwood
CONs
That's the only thing I don't like about the Atwood/Dometic HW Tank. Having things on the backside that might need to be replaced. That can be a difficult task by some RV Owners.
Old-Biscuit
Verde Valley
Posted: 10/14/20 12:05pm Link  |  Quote  |  Print  |  Notify Moderator
RobWNY wrote:
Old-Biscuit wrote:
Atwood
CONs
Especially when the 'RV Engineer/Designer' designates WH Location that requires REMOVAL to get to element etc
STUPID!
Guy Roan
Posted: 10/15/20 01:04am Link  |  Quote  |  Print  |  Notify Moderator
I'll take the soft plastic drain plug any day !
We don't need to ever change a anode on our residential water heaters, so why should we have to in a RV
Guy
DrewE
Vermont
Posted: 10/15/20 01:23am Link  |  Quote  |  Print  |  Notify Moderator
Guy
Standard tank-style residential water heaters do have anode rods, and one is well-advised to replace them as they get consumed so that the tank doesn't rust out and start leaking too soon. How rapidly they are consumed or caked up in deposits does, of course, depend a good deal on the nature of one's water supply.
Lynnmor
Red Lion
Posted: 10/15/20 01:31am Link  |  Quote  |  Print  |  Notify Moderator
Guy
Yep, one of the most neglected items in home maintenance. The big home centers stopped stocking them since sales were so low and they would rather sell new water heaters every few years. My anodes need replaced every three years. The water heater in my shop doesn't even have access to the anode, the top needs to come off.
Wherever I happen to park
Posted: 10/15/20 04:38am Link  |  Quote  |  Print  |  Notify Moderator
Well I have an Atwood. and am happy with it. I like that it is very easy to choose Gas or Electric.. WIth some suburban models you need to go out side to do that. With my Atwood two switches on the inside control panel side by side.
Home is where I park it.
