RV.Net Open Roads Forum: Fifth-Wheels: Residential W/D?
 > Residential W/D?
Cummins12V98
on the road
Posted: 10/16/20 09:12am Link  |  Quote  |  Print  |  Notify Moderator
Campinfan wrote:
Looks like Cummins12v98 got it to work. Not sure how hard it would be to run 22o to the area...I am not an electrician or a plumber but I am pretty handy. Never saw the gray pipe type setup in the photo before, are those to help prevent leaks or are they backflow preventers?
Mine came prepped with 30A 220V for the dryer. The Washer and dryer amp draw was well within the 30A breaker and wire size. If I had a Bosch dryer the Bosch washer would simply plug into the dryer.
If you are handy it should not be hard to run. I would use 10/3 with ground in 10ga using "SO" cord as it's very easy to bend as needed and is fully jacketed.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
memtb
Wyoming
Posted: 10/16/20 09:25am Link  |  Quote  |  Print  |  Notify Moderator
way2roll wrote:
Forgive me if this has been asked before, our FW is equipped with W/D hookups. It's spec'd for side by side but I imagine an all in one or stackable would work too. As we shop for them, does it have to be an RV specific set, or can residential units be modified to use? And how do they get them in the RV to install them? Going to be a pretty tight fit getting it in the door and up the hallway into the hookups in the bedroom closet.
We have GE Space Saver washer and dryer in our 5th wheel . They are residential....but for apartment type applications. I can’t vouch for the quality and performance of the newer GE’s, but, we are very happy with ours. Fairly large load capacity and extremely quiet. When they are in use.....you must listen carefully to determine that they are still running!
Also......They are 110/120 volt! memtb
Todd & Marianne
Miniature Schnauzer's - Sundai, Nellie & Maggie Mae
2007 Dodge Ram 3500, 6.7 Cummins, 6 speed manual, 3.73 ratio, 4x4
2004 Teton Grand Freedom, 39'
2007 Bigfoot 30MH26Sl
 > Residential W/D?
