RV.Net Open Roads Forum: Fifth-Wheels: Installing a second battery
 > Installing a second battery
way2roll
Wilmington NC
Posted: 10/16/20 08:49am Link  |  Quote  |  Print  |  Notify Moderator
Our FW is new. That said it's a 2020 and I am sure sat on the lot for a few months. It has one battery and it has solar so it keeps it topped off. I've never run it lower than 70%. As I think about boondocking, I was going to add another one in series. I had done this on previous MH's we had. But my question is really around the battery itself. Knowing Batts perform best when they are all the same. When I did my MH it was time to change them so when I added them they were all the same brand, type and age. Since my FW is pretty new, do I need to be overly concerned with the exact same brand and model battery? Any concerns about one being potentially a year older than the new one? And putting them in a series shouldn't change a thing as far as the solar/shore power charging them both right?
Thanks!
2020 FR Cedar Ridge Silverback 29rw
RoyF
Fayetteville Arkansas
Posted: 10/16/20 09:01am Link  |  Quote  |  Print  |  Notify Moderator
If you have a 12-volt battery then you want the second battery to be in parallel because your systems require 12 volts only. Charge both batteries to the same voltage before connecting them in parallel. (If there were much difference in voltage then you would get a large current when they were first connected in parallel -- I don't know what might actually happen).
way2roll
Wilmington NC
Posted: 10/16/20 09:05am Link  |  Quote  |  Print  |  Notify Moderator
I think I meant parallel - POS to POS, NEG to NEG. So I should bench charge them to the same Voltage. Makes sense.
near Jawbone Canyon, CA
Posted: 10/16/20 09:31am Link  |  Quote  |  Print  |  Notify Moderator
Just might be time to buy two 6s and not waste time and money on another 12. Solar watts should equal or exceed total batter amp hours.
time2roll
Posted: 10/16/20 09:50am Link  |  Quote  |  Print  |  Notify Moderator
Get a second battery and go have some fun.
Not a huge issue really.
675w Solar pictures back up
Posted: 10/16/20 10:11am Link  |  Quote  |  Print  |  Notify Moderator
"As I think about boondocking..."
Do an energy survey (what you will use or what you want to use) and then times 1.5. That number will help you determine what battery amp hours you need. I use 70 or so amps per day so my number is 100. My T125 are 240 amps hours. Plenty and a reserve for boondocking.
KD4UPL
Swoope, VA
Posted: 10/16/20 12:34pm Link  |  Quote  |  Print  |  Notify Moderator
If your battery is a year or less adding a similar one in parallel shouldn't cause any problems. If it were, say, 3 years old it would not play as well with the new one.
Ideally parallel batteries should be the same type (AGM or flooded) and size. Brand shouldn't be that big of a deal, particularly since all batteries are made by about 4 companies anyway.
In the future, when you need to replace all your batteries I would look at using 6 volt golf cart batteries in series.
pianotuna
Regina, SK, Canada
Posted: 10/16/20 01:44pm Link  |  Quote  |  Print  |  Notify Moderator
Be sure to wire them in a balanced manner.
Regards, Don
Super_Dave
Harrisville, UT
Posted: 10/16/20 03:56pm Link  |  Quote  |  Print  |  Notify Moderator
In my 5th wheel, I've got 2 batteries. I put the negative cable from the 5er on the negative post of battery 1 and the positive cable on the positive post of battery 2. The + to + and - to - from each battery is tied together. It works, someone can tell me if I'm screwing anything up.
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 21' North River Seahawk
pianotuna
Regina, SK, Canada
Posted: 10/16/20 10:48pm Link  |  Quote  |  Print  |  Notify Moderator
Super Dave,
The way you have them wired is correct, and can not be improved on.
