RV.Net Open Roads Forum: Tech Issues: Tire Inflation - What RU Using
 > Tire Inflation - What RU Using
riltri
Lansing
Posted: 10/16/20 08:59am Link  |  Quote  |  Print  |  Notify Moderator
My small tire pump is really struggling to get tires to 80 psi. Also, the cord won't reach from truck to rear tires. What are you using?
Blue Ridge Mtns - NC
2oldman
Mecca
Posted: 10/16/20 09:04am Link  |  Quote  |  Print  |  Notify Moderator
Rolair 1 gallon compressor with a 50' hose
agesilaus
North Florida
Posted: 10/16/20 09:05am Link  |  Quote  |  Print  |  Notify Moderator
Viair 00088 88P Portable Air Compressor
Works great and has a long enough air hose and power leads to reach all the tires.
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
RoyF
Fayetteville Arkansas
Posted: 10/16/20 09:11am Link  |  Quote  |  Print  |  Notify Moderator
I use a Husky air compressor from Home Depot. It goes up to 110 psi. But since I purchased new trailer tires from Discount Tires, that store has been letting me have free air from their compressor, which works a lot faster than my Husky compressor.
Camping near Pearsonville, CA
Posted: 10/16/20 09:29am Link  |  Quote  |  Print  |  Notify Moderator
Ryobi battery powered air pump but I only need a max of 65. Recharge from truck's 110 plug. Powers my saw, drill and impact wrench too. Five years now.
fj12ryder
Platte City, MO
Posted: 10/16/20 09:39am Link  |  Quote  |  Print  |  Notify Moderator
A 120v Porter Cable rated to 150 psi.
Howard and Peggy
"Don't Panic"
Boomerweps
Hills of PA
Posted: 10/16/20 11:02am Link  |  Quote  |  Print  |  Notify Moderator
One of those small dual tank compressors from a Harbor Freight. $45-50. Easier to move around than my larger 10 gallon horizontal shop compressor. Both 120VAC.
2019 Wolf Pup 16 BHS Limited, axle flipped
2019 F150 4x4 SCrew SB STX 5.0 3.55 factory tow package, 7000#GVWR, 1990 CC
rlw999
Washington State
Posted: 10/16/20 11:12am Link  |  Quote  |  Print  |  Notify Moderator
I use a "Slime 40026 2X Heavy Duty Direct Drive Tire Inflator" pump that I found on sale for $60. The power cord is short, but the hose is long (it takes a really heavy power cord to carry enough current for a 12V pump, that's why it comes with a long hose).
I tried using a cheap cigarette lighter pump and ran into the same problem as you -- it could barely make it over 70psi, but I needed to get to 80psi.
If you get a 12V pump, get one with battery clamps, not a cigarette lighter adapter, the cigarette lighter can't put out much current, so those pumps don't have a lot of power.
If money is no object, ViAir has some great 12V pumps, but they are not cheap.
DrewE
Vermont
Posted: 10/16/20 11:16am Link  |  Quote  |  Print  |  Notify Moderator
I use, and am highly satisfied with, a Fini AirBoss compressor. This is among the most compact "real" compressors available, and not as loud as some though by no means quiet. I have no trouble getting my tires to 80 psi with it, and without needing an overly long time to do so.
(Craftsman also rebrands the same unit.)
ksg5000
Oregon
Posted: 10/16/20 12:46pm Link  |  Quote  |  Print  |  Notify Moderator
I use a home pancake compressor b4 I take off ... on the road I carry an electric compressor which takes a LONG time to fill but I rarely have had to use it. Seems like a decent compromise for someone who isn't on the road for a long time.
Kevin
