RV.Net Open Roads Forum: Tech Issues: Tire Inflation - What RU Using
 > Tire Inflation - What RU Using
down home
south
Posted: 10/16/20 12:49pm Link  |  Quote  |  Print  |  Notify Moderator
We ran across the same problem, with oru compressor factory set at 125 psi, it jsut wouldn't do it. Newmar has a pressure doubler or did from the factory near the compressor. Others are available, but hard to find. I've been meaning to install a Newmar doubler for years and have yet t do it. A couple or three hundred dollars and a few minutes it seems is about all that is required.
* This post was edited 10/16/20 12:55pm by down home *
RobWNY
Jamestown, NY
Posted: 10/16/20 12:52pm Link  |  Quote  |  Print  |  Notify Moderator
I use this one. VIAIR - 40045 400P-Automatic Function Portable Compressor As previously mentioned, between the hose and power leads, I can reach all of my tires.
2020 Silverado 2500HD LT, CC, 4X4 6.6 Duramax
2021 Grand Design Reflection 311BHS
I asked him to do one thing and he didn't do any of them.
fpresto
Maryland
Posted: 10/16/20 03:01pm Link  |  Quote  |  Print  |  Notify Moderator
Also VIAIR. Perfect small compressor.
USN Retired
2016 Tiffin Allegro 32 SA
Homeless by Choice
North America
Posted: 10/16/20 03:27pm Link  |  Quote  |  Print  |  Notify Moderator
VIAIR X3
It has Heavy Duty Battery cables and a long hose to easily reach all my tires. I had mine since 2012 and it works flawlessly every time.
LeRoy
Homeless by Choice
FULL TIMER since 2012
2015 Chevy 3500, Duramax, 4X4, DRW, Crew cab, Long bed
2013 Northern Lite 8'11"Q Sportsman truck camper
2015 Polaris RZR Side by Side
rhagfo
Portland, OR
Posted: 10/16/20 03:49pm Link  |  Quote  |  Print  |  Notify Moderator
VIAIR here also only mine is constant duty mounted under the bed side rail. Rated at 150 psi with a 2.5 gallon tank, air chucks in the bed and under the hood.
VIAIR on board.
Ed_Gee
Central Oregon coast
Posted: 10/16/20 08:31pm Link  |  Quote  |  Print  |  Notify Moderator
Viair 88P for me. Tires only require 70PSI and snall RV has limited storage. Viair is small, reliable, and high quality.
Ed - on the Central Oregon coast
2018 Winnebago Fuse 23A
Scion xA toad
time2roll
Posted: 10/16/20 08:34pm Link  |  Quote  |  Print  |  Notify Moderator
MV-50 running fine 15 years now. Did need to get a new hose.
675w Solar pictures back up
8ntw8tn
Southeast Iowa & Texas Hill Country
Posted: 10/16/20 09:35pm Link  |  Quote  |  Print  |  Notify Moderator
fj12ryder wrote:
A 120v Porter Cable rated to 150 psi.
X2
'08 Chevy Silverado 3500 Duramax;
'10 Carriage Cameo F35FWS
Det 1 56th SOWg
Posted: 10/17/20 04:28am Link  |  Quote  |  Print  |  Notify Moderator
I have a Crafstman 120 volt pancake style (6 gallon) 150 PSI rated (160 actual) that does a great job on my 110 PSI tires.
It (with the help of a Harbor Freight 12 ton air/hydraulc jack-jack) can pick up the motor home for maintenance tasks.
Roger10378
Goodrich, MI.
Posted: 10/17/20 07:36am Link  |  Quote  |  Print  |  Notify Moderator
Most all of the major companies that make battery powered tools now have air compressors. If you have any of these tools you can buy the air compressor that goes with the other tools you have.
2005 Cardinal 30TS
2007 Chevy 2500HD D/A
