RV.Net Open Roads Forum: Easy way to tell what outlets are on my inverter?
 > Easy way to tell what outlets are on my inverter?
way2roll
Wilmington NC
Posted: 10/16/20 09:43am Link  |  Quote  |  Print  |  Notify Moderator
Our FW has residential appliances. I know the Fridge is on the inverter but I am unsure what else is. Oddly enough - our stove, which is gas, is not. It requires shore power for the igniter which I thought was pretty odd. I can't use the oven while boondocking - although I haven't tried lighting by hand. Outlets, central vac etc, all not on the inverter. TV's are all on 12V as is all the lighting. Slides and jacks are 12V. Is my refer the only thing on the inverter? How do I tell?
2020 FR Cedar Ridge Silverback 29rw
near Jawbone Canyon, CA
Posted: 10/16/20 10:13am Link  |  Quote  |  Print  |  Notify Moderator
An RV gas stove that doesn't light via 12 volt? Wow.
K Charles
Connecticut
Posted: 10/16/20 10:27am Link  |  Quote  |  Print  |  Notify Moderator
Unplug from shore power if the outlet works it's on the inverter.
newman fulltimer
louisiana
Posted: 10/16/20 11:52am Link  |  Quote  |  Print  |  Notify Moderator
Furrion stove is gas only other than the 12 volt lights for the backlighting
hotjag1
Lake Chelan, Wa/Lake Havasu, Az.
Posted: 10/16/20 01:25pm Link  |  Quote  |  Print  |  Notify Moderator
Are you sure about your stove? I thought the ignitor would be 12 volt.
hotjag1
2003 40' Allegro Bus, 3 slides, 400hp 8.9 liter ISL Cummins
2000 24' Dynamax Isata
way2roll
Wilmington NC
Posted: 10/16/20 01:46pm Link  |  Quote  |  Print  |  Notify Moderator
Yep I am sure. Lights work etc. No igniter on the stove. Thought it was very strange. And we had used the stove the same morning to make breakfast while still on shore power. I have not checked it on the inverter, but a spark igniter should be 12V I would think.
Pangaea Ron
Anacortes, WA, USA
Posted: 10/16/20 04:00pm Link  |  Quote  |  Print  |  Notify Moderator
^^^This
2008 Itasca SunCruiser 35L
2014 Honda AWD CR-V EX-L
wopachop
Who run bartertown
Posted: 10/16/20 04:19pm Link  |  Quote  |  Print  |  Notify Moderator
Is the stove not lighting because the battery disconnect switch is off?
MitchF150
Puyallup, WA
Posted: 10/16/20 06:41pm Link  |  Quote  |  Print  |  Notify Moderator
My stove top uses a single AA battery for the burners.. To light the actual 'oven', you have to light the pilot and let it run, or just use the clicker on it to light the pilot. Oven won't fire without the pilot going as far as I know... Actually have never used it yet! ha, ha...
I pulled the AA battery for the burners because if you lean on it while reaching for the something in the upper cabinet, your hip pushes the button and engages the igniter.
I just use the good old 'clicker' lighter and works great! [emoticon]
Mitch
sdfiver
Rapid City, SD
Posted: 10/16/20 08:19pm Link  |  Quote  |  Print  |  Notify Moderator
We have one of the Furrion stainless steel cooktops and oven in our rig and it uses a battery in the little ignitor button.
2016 F-350 6.7L Super Duty Platinum
2019 Heartland Bighorn 3760EL
