RV.Net Open Roads Forum: Fifth-Wheels: Dualie vs SRW benefits?
 > Dualie vs SRW benefits?
work2much
Jackson Ca
Posted: 10/17/20 10:28am Link  |  Quote  |  Print  |  Notify Moderator
Dually has the payload to handle pin weight. As an example our Dually has a cargo capacity of 5200 pounds. Our 15k gvwr 5th wheel has a pin weight of 3100 pounds. Add our aux fuel tank/tool box, fuel, passengers, dogs, small generator, hitch, wheel chocks and we are close to 5000 pounds of cargo capacity. A SRW would be over the cargo numbers for sure. I see many who do run over their trucks cargo ratings even guys with 3/4 ton trucks towing 3 axle toy haulers. Not here to judge others choices but for us we like the stability and cargo capacity of our dually.
2017 Ram 3500 Laramie CTD DRW Crew 4x4 Aisin 4:10 Air ride.
2020 Grand Design Solitude 2930RL 2400 watts solar. 600ah lithium. Magnum 4000 watt inverter.
blaczero
Posted: 10/17/20 10:45am Link  |  Quote  |  Print  |  Notify Moderator
Hey everyone, thank you all for the great replies, I have learned a lot.
I am looking at a Chaparral 373mrbr which is listed as 15k GVWR so I think dualie (training wheels, hah) will be better. I actually found a new f350 crew cab dualie for 50,700 online so I am pursuing that.
Thanks again to everyone so far.
Retired JSO
North Georgia Mountains
Posted: 10/17/20 11:14am Link  |  Quote  |  Print  |  Notify Moderator
18 F350 Lariat DRW FX4, is a pleasure to drive and tow.
Rear GAWR 9900
Cargo capacity 5507
rhagfo
Portland, OR
Posted: 10/18/20 12:25am Link  |  Quote  |  Print  |  Notify Moderator
That is a very low price for new, is it gas or diesel and what is the trim level?
When we were looking used, we knew we wanted Ram, Diesel, Aisin trans, 3.73's and power drivers seat. I am prone to leg cramps if seated in the same position for too long. Power seat allows me to change seat cushion angle. Well had typo be at least a SLT, with power seat option, Big Horn, drivers 6 way, well ended up with a Laramie with drivers 10 way and passenger 6 way seat.
I will say that "Base" trim levels are coming out nicely lately.
blaczero
Posted: 10/18/20 12:34pm Link  |  Quote  |  Print  |  Notify Moderator
Crew cab, 7.3L gas, XLT with power pedals/seat, 5th wheel prep, dualie, with bench seat, no nav.
Almost perfectly what I wanted, only thing I don't like is it's white.
Allworth
Orlando, FL
Posted: 10/18/20 03:50pm Link  |  Quote  |  Print  |  Notify Moderator
Diesel
Diesel
Diesel
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
2008 Titanium 30E35SA; EZ-Lube axles; wet bolts; spring hanger gussetts; BFG Commercial TAs
"Real Jeeps have round headlights"
rhagfo
Portland, OR
Posted: 10/18/20 04:13pm Link  |  Quote  |  Print  |  Notify Moderator
Allworth wrote:
Diesel
Diesel
Diesel
Well TFL tested the Ford 7.3 Godzilla in a F250 and other than being very thirsty it did very well. I believe it was towing 16,000#.7.3 Godzilla test
Not my cup of tea, I like the effortless tow with a diesel.
Crespro
SoCal
Posted: 10/18/20 09:25pm Link  |  Quote  |  Print  |  Notify Moderator
This F-350 DRW could be ordered with about $3K discount. For $54K, this is a fine vehicle. Yes, it does not pull like a diesel, but for a fifth wheel up to about 16K, it will perform quite well.
Base MSRPS1 $46,305 Total of OptionsS4 $8,915 Destination ChargesS17 $1,695 Total MSRPS16 $56,915
2020 Ford Super Duty F-350 XLT Crew Cab®, 8’ Box, 7.3L 2V DEVCT NA PFI V8 Engine, TorqShift® 10-speed Automatic Transmission, 4.30 Limited Slip Axle Ratio, 4X2, DRW$46,305
Iconic Silver$0 7.3L 2V DEVCT NA PFI V8 Engine 4X2 TorqShift® 10-speed Automatic Transmission with Selectable Drive Modes 4.30 Limited Slip Axle Ratio
Ultimate Trailer Tow Camera System with Pro Trailer Backup Assist™$1,600 XLT Value Package $1,600
11,400 (SRW)/13,000 (DRW Only) GVWR Package $0 Tailgate Step with Tailgate Assist $375 Bedliner – Tough Bed® Spray-in $595
5th-Wheel/Gooseneck Hitch Prep Package$500
Hitch Kit – 5th Wheel, 27.5K $1,495 6-inch Angular Chrome Running Boards $695
Crespro 2021 Grand Design 310GK-R, 2020 F250LB, 7.3L, 4.30, Reese 27K
4x4ord
Alberta
Posted: 10/18/20 11:35pm Link  |  Quote  |  Print  |  Notify Moderator
The difference in price between a diesel srw and a 7.3 litre gasoline powered dually is about $6500. You’d likely get $5k of that back 12 years down the road. For a 15k fiver I think you’d be much happier with a SRW diesel than a dual wheeled gasser.
* This post was edited 10/18/20 11:50pm by 4x4ord *
2017 F350 SRW Platinum short box 4x4.
B&W Companion
rhagfo
Portland, OR
Posted: 10/18/20 11:38pm Link  |  Quote  |  Print  |  Notify Moderator
4x4ord wrote:
The difference in price between a diesel srw and a 7.3 litre gasoline powered dually is about $6000. You’d likely get $5k of that back 12 years down the road. For a 15k fiver I think you’d be much happier with a SRW diesel than a dual wheeled gasser.
The diesel should also be a DRW due to the loss of payload due to the weight of the diesel.
