RV.Net Open Roads Forum: Class A Motorhomes: Years of auto park brake
 > Years of auto park brake
base1957
Posted: 10/16/20 08:00pm Link  |  Quote  |  Print  |  Notify Moderator
looking to purchase another class a or a diesel.... how do i avoid the dreaded Auto park brake system... what years were they used... were they on all models...
thanks in advance
RLS7201
Posted: 10/16/20 08:10pm Link  |  Quote  |  Print  |  Notify Moderator
The auto park brake system was used on the Chevy P32 chassis, which is some times misidentified as a P30 chassis.
Richard
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
First brake job
1941 Hudson
olfarmer
Iowa
Posted: 10/16/20 10:20pm Link  |  Quote  |  Print  |  Notify Moderator
My 2001 Winnebago Brave has it, I haven't had trouble with it but it does worry me that it could fail.
Ed & Ruby & the 2 cats
2001 Winnebago Brave 30W
7.4 gas Work Horse Chassis
99 Jeep Grand Cherokee
rgatijnet1
Posted: 10/17/20 05:50am Link  |  Quote  |  Print  |  Notify Moderator
Richard
The WORKHORSE P30, used on many Class A coaches, had the auto park brake and had nothing to do with Chevrolet. The Workhorse production of the P30 chassis ended in 2005. Workhorse continued to offer the W chassis for RV's.
base1957
Posted: 10/17/20 07:47am Link  |  Quote  |  Print  |  Notify Moderator
Is the autopark brake tied to winnebago, or the specific chassis?
In other words rvs like tiffin, Fleetwood etc..do they have them also?
olfarmer
Iowa
Posted: 10/17/20 08:13am Link  |  Quote  |  Print  |  Notify Moderator
I don't believe it was just Winnebago, any make built on that workhorse chassis would have the auto park. I think it was just used on the P series chassis and when they went to the W series chassis it was eliminated because they used a different transmission.
base1957
Posted: 10/17/20 08:31am Link  |  Quote  |  Print  |  Notify Moderator
has anyone used the upgraded RGS by ultra rv?
Gjac
Milford, CT
Posted: 10/17/20 11:22am Link  |  Quote  |  Print  |  Notify Moderator
To answer you question directly. The autopark system was used on the P-30 Chevy chassis from 1989 to about 2006. No not all chassis used this system. The lighter Chevy chassis under a certain weight did not. I believe the weight limit was less than 10,000 lbs. They can be very problematic I have one in my MH. You can live with it once you understand how the system works if you are fairly handy.
tropical36
Southwest Florida_USA
Posted: 10/18/20 09:23am Link  |  Quote  |  Print  |  Notify Moderator
thanks in advance
This was a GM design that was around for awhile, before the P32 chassis was sold to Workhorse in 1999. Not such a bad system, actually and as long as one educated themselves on it's operation and for carrying a few parts on board and especially the green hydraulic pressure switch for the version III.
Some were installed on the WH W chassis, as well and even though it might have an Allison Transmission. The whole thing is about having a tranny that doesn't have a parking pawl due to liability concerns over weight restrictions.
Read on.....
Technical Inquiries: August 2004
September 1, 2004
Auto-Park Brake Questions
A: Recently we’ve received several questions regarding the auto-park brake system used on some Workhorse P Series gasoline-powered motorhome chassis. To help owners understand how the system works, what could cause it to fail, and the results of such a failure, we contacted the company for an explanation. A product service technician at Workhorse provided the following information.
The auto-park brake system (option J71) is used on all P Series chassis equipped with Hydra-Matic 4L80-E and 4L85-E (the latter starting with 2003 model year) transmissions and with gross vehicle weight ratings (GVWR) above 15,000 pounds. This brake replaces the foot parking brake and parking pawl used on similar units rated at less than 15,000 pounds GVWR. (The parking pawl on the 4L80E transmission is rated at a maximum of 15,000 pounds GVWR.) Workhorse chassis (W Series) equipped with Allison 1000 MH transmissions do not have auto-park brakes; they have parking pawls. However, the new W24 (2004 model) chassis with an Allison 2100 MH transmission does have an auto-park brake system, as this transmission has no parking pawl. Allison transmissions are not available on P Series chassis.
The foundation for the auto-park brake system is a drum-type brake mounted on the rear of the transmission. When the brake shoes are applied against the drum, they stop rotation of the prop shaft, which holds the rear wheels from rotating. A spring-loaded chamber mechanically applies the brake. A hydraulic cylinder that obtains pressure and flow from an electric-powered pump releases the brake.
The brake is applied when the shift lever is put in the “park” position. The brake is activated when the park neutral switch and relay remove a 12-volt-DC power supply to a normally open solenoid valve. The valve dumps the oil pressure that holds the spring compressed, and the spring mechanically applies the parking brake. When the shift lever is moved to any gear position, 12-volt-DC power goes to the solenoid valve and it closes. At the same time, an electric-powered hydraulic pump provides pressure and flow to a cylinder that compresses the spring and releases the brake. The operation is similar to that of spring-activated parking brakes on air-brake-equipped units.
For a parking brake to meet Department of Transportation (DOT) standards, it must fail in a safe mode so that the parking brake is activated or remains activated in the event of any failure within the system. This means that any failure will result in the parking brake being applied or not being released. This is a desirable feature and is required to prevent a parked vehicle from rolling in the event of a system failure. For example, any loss of power to the solenoid valve, including a dead battery or a loose battery connection, can cause the brake to apply. Similar designs are used throughout the industry on motorhomes, buses, and trucks. Other failures that could cause the brake to apply include loss of fluid pressure resulting from leaks in the system, or contaminated fluid.
Owners also should be aware that connecting add-on electrical devices to the same circuit or wiring as the auto-brake have been known to cause problems. If you decide to add an aftermarket backup camera, obstacle sensing device, and/or a backup warning device, make sure it is fused separately if wired to the backup lights. The backup lights are most often wired through the neutral safety switch that is necessarily fused on the same circuit as the auto-park brake, as this is the switch that actuates it.
One concern owners have expressed is, what would happen if the brake should apply at high speed? The vehicle will come to a slow stop, as it does not have sufficient power to lock and skid the rear wheels, unless the vehicle is traveling on an icy or a slippery surface. However, severe damage can occur to the brake and it may not hold the unit in a parked position. In this case, the brake immediately should be checked, repaired, and adjusted as necessary. The prop shaft will not be damaged.
Should the brake become locked in a no-release condition due to a failure, it cannot be mechanically released. However, a qualified technician can remove the cable pin. This will release the brake, but the unit will not have a parking brake and cannot be parked without blocking the wheels.
To reduce the possibility of having an auto-brake failure, Workhorse recommends a yearly inspection of the system for loose connections, corrosion of components, adjustments, reservoir fluid level, fluid condition, and system operation. The cable should be adjusted at least once every year. The system has a light and buzzer that warns the operator if an adjustment is needed. The adjustment is required to provide proper holding power and is not related to failure to release. The system also should be inspected to make sure that added items such as reverse bells/lights or any other added equipment is not installed on the same circuit or wiring as the auto-park brake. An electrical overload resulting from such added items has caused the parking brake to apply or not release.
In May 2001 Workhorse issued technical bulletin 80101-T that described chassis wiring improvements for 2001 model-year chassis (after VIN# 5B4LP57G51333218 on March 12, 2001). One of the changes was to separate the circuits used for the auto-park brake and signal lights so that a shorted or improperly wired towed vehicle would not interfere with the auto-park brake.
Some owners have asked whether a replacement kit is available to convert the auto-park brake system into a pedal- or lever-type system as is used on some commercial trucks. The answer is no. All chassis equipped with automatic transmissions and hydraulic brakes without parking pawls have the auto-brake system to comply with DOT standards. This includes all Workhorse gasoline-powered chassis with Allison transmissions other than the 1000 MH transmission, which has a parking pawl.
"We are often so caught up in our destination that we forget to appreciate the journey."
07 Revolution LE 40E_Spartan MM_06 400HP C9 CAT_Allison 3000.
Dinghy_2010 Jeep Wrangler JKU ISLANDER.
1998 36ft. National Tropi-Cal Chevy Model 6350 (Sold)
