RV.Net Open Roads Forum: 12 volt receptacles shorting 12 volt accessory charge cords
 > 12 volt receptacles shorting 12 volt accessory charge cords
billyray50
North Dallas
Posted: 10/17/20 07:55am Link  |  Quote  |  Print  |  Notify Moderator
We bought a 2020 Jayco precept 34g gas motorhome with the ford f53 chassis and v10 engine. The coach has 3 12 volt dc outlets in the cockpit. So far while trying to charge GPS and TPMS monitor and not both at same time the charge cords shorted out. Also blew 12 volt cord for a sharper image seat cooler inline 6 amp fuse. Seat cooler was the only item plugged in at the time. Help!
MountainAir05
New Mexico
Posted: 10/17/20 08:23am Link  |  Quote  |  Print  |  Notify Moderator
take a reading off the connector. I am only reading that it shorts out what you plug into it.
BB_TX
McKinney, Texas
Posted: 10/17/20 08:41am Link  |  Quote  |  Print  |  Notify Moderator
What exactly do you mean by "charge cords shorted out"?
billyray50
North Dallas
Posted: 10/17/20 09:01am Link  |  Quote  |  Print  |  Notify Moderator
Both 12 volt charge chords for GPS and TPMS monitor will not work anymore. Also 12 volt cell phone chord keeps blowing fuses. Two separate phone chargers.
Matt_Colie
Southeast Michigan
Posted: 10/17/20 09:04am Link  |  Quote  |  Print  |  Notify Moderator
Billyray,
You should be aware that there are no standards for the ubiquitous 12V mousehole. So, there are no "standard" sockets and no guaranteed to fit plugs to go in them. There is also no designed means to retain any plug. I could actually go on for a while longer about the things that are bad about them.
It sounds to me like you just ran into things that are incompatible.
I can't tell you what to do about it other than try other things. If the plug you are using delivers power and doesn't blow a fuse, you can sometimes get it to stay put by jamming a toothpick in there.
Matt
Matt & Mary Colie
A sailor, his bride and their black dogs going to see some dry places that have Geocaches in a coach made the year we married.
billyray50
North Dallas
Will do. Thanks.
dougrainer
Carrolton, Texas
Posted: 10/17/20 09:22am Link  |  Quote  |  Print  |  Notify Moderator
The Plugs are NOT Ford. So, I will bet the polarity of the plugs are reversed. THAT is why you are destroying the cords. The OUTER silver case is Negative and the inside rear is the positive. IF reversed, it is very easy to gain access on a Precept to reverse the spade terminals on the back of the receptacles. Also, KEEP the bad cords and receipts for them. Jayco will reimburse you thru your Jayco dealer. IF indeed it is reverse polarity. IF you fix it yourself, TAKE PICS of the reversed wiring and then when it is corrected. Doug
Executive
Posted: 10/17/20 09:42am Link  |  Quote  |  Print  |  Notify Moderator
There are only two reasons why you would experience what you are getting. One, the receptacles are not 12VDC and reverse polarity. I believe Doug has answered the reverse polarity issue which is more common than you think. Rarely will you find them wired with a 120VDC circuit. The plugs simply screw out and they're pretty easy to get to. Hold the outside part and unscrew the inside part. Use a meter to check voltage. Since you're experiencing the same issue with all three, it's in the wiring. If someone wired one wrong they wired all three wrong. Easy and cheap fix...Dennis
A Simple Act of Caring Creates an Endless Ripple
Dennis and Debi Eleven Years Full Timing
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
MrWizard
Traveling
Posted: 10/17/20 10:56am Link  |  Quote  |  Print  |  Notify Moderator
Reverse polarity on 12v ?
Maybe
Most 12vdc would simply not work, except 12v fans would run backwards, and 12v incandescent interior RV lamps would light
Problem
The items mention use 5v internally
Reverse polarity would mess with voltage regulation on the circuit boards, creating overload conditions, If the device even turned on and worked
Did These incidents occur while parked
Are these outlets powered by RV 12v circuit?
Converter voltage could be Too High
Or
It could have A.C. voltage ripple in the DC output
Either way it would be a converter problem
Radiate The Happy
1997 F53 Bounder 36s
hotjag1
Lake Chelan, Wa/Lake Havasu, Az.
Posted: 10/17/20 11:04am Link  |  Quote  |  Print  |  Notify Moderator
I had exactly the same problem because I had wired them backwards..."reverse polarity". Switched the 2 wires around and they work perfectly.
hotjag1
2003 40' Allegro Bus, 3 slides, 400hp 8.9 liter ISL Cummins
2000 24' Dynamax Isata
