RV.Net Open Roads Forum: Class A Motorhomes: compartment door latch 96 Wbago Vectra
 > compartment door latch 96 Wbago Vectra
base1957
Posted: 10/17/20 09:23am Link  |  Quote  |  Print  |  Notify Moderator
Looking for two of these if anyone has any?
Bago no longer makes em
thanks in advance
9 101348-01-000EABOLT-SLIDE, LATCH - NYLON - W/SPRING & BRKT
http://www.winnebagoind.com/service/wincd/1996/96km34rq.pdf
Executive
Posted: 10/17/20 09:53am Link  |  Quote  |  Print  |  Notify Moderator
A picture helps more than 106 pages of gibberish. If you don't know how to post a picture, simply click HERE, put your picture in the box and copy the link provided into your post......Dennis
A Simple Act of Caring Creates an Endless Ripple
Dennis and Debi Eleven Years Full Timing
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
base1957
Posted: 10/17/20 10:31am Link  |  Quote  |  Print  |  Notify Moderator
thanks executive.... no i did not know how
here is the pic
base1957
Posted: 10/17/20 10:34am Link  |  Quote  |  Print  |  Notify Moderator
in fact executive... i looked for the way to do that... and still cant find it ...the only way i was able to do it is because you sent the HERE link... where do i find that in this rv net site?
thanks in advance
emiddleb
Michigan
Posted: 10/17/20 11:48am Link  |  Quote  |  Print  |  Notify Moderator
It in the "Technical Resources" => "Forum Posting and Help" subforum, third sticky down. "RV.net and Picture Related FAQs" posting.
2004 Winnebago Vectra 40KD
Roadmaster Tow Dolly
DrewE
Vermont
Posted: 10/17/20 01:24pm Link  |  Quote  |  Print  |  Notify Moderator
You may well be able to get used but serviceable ones from an RV salvage yard.
Failing that, in your shoes I'd probably see about constructing a replacement part, say by cutting and drilling a piece of square aluminum stock. It doesn't look like too complicated of a piece: an angled end for the latch itself, a hole for the pull rod, and a hole for a cross-pin to catch the spring.
One could also 3D print (or have 3D printed) the bolt of the latch once the design is reproduced in a CAD or other 3D design program; printing in nylon is possible but somewhat tricky and requires a printer more capable than the basic models (and likley an enclosure). I'm not sure PLA or other more common 3D printed plastics would hold up all that well here.
enblethen
Moses Lake, WA
Posted: 10/17/20 02:24pm Link  |  Quote  |  Print  |  Notify Moderator
try Colaw as they have many RV parts both new and old. Send them the photo.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
base1957
Posted: 10/17/20 03:26pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the suggestions so far...i tried Colan amd no luck...
Making a couple may indeed the best idea
base1957
Posted: 10/17/20 03:28pm Link  |  Quote  |  Print  |  Notify Moderator
enblethen
Moses Lake, WA
Posted: 10/17/20 04:37pm Link  |  Quote  |  Print  |  Notify Moderator
What is wrong with yours?
