RV.Net Open Roads Forum: Travel Trailers: Winterizing queston
 > Winterizing queston
wtmtnhiker
New Hampshire
Posted: 10/17/20 11:50am Link  |  Quote  |  Print  |  Notify Moderator
Hi all,
I have been using compressed air to winterize for the last few seasons and prefer this method over antifreeze. This season though I used my fresh water tank and pump while boondocking a few times. Is there a method to get air flowing through the pump and related plumbing or do I need to run antifreeze through it? Thanks.
bgbassman(bluegrass bass man)
MFL
Midwest
Posted: 10/17/20 12:45pm Link  |  Quote  |  Print  |  Notify Moderator
You could let the pump run dry for a minute or so, but IMO, it would be safest to run some pink through it. Pretty simple if you have a winterizing kit/hose attached. Pumping that little bit through the toilet line, would be a good choice.
Jerry
RobWNY
Jamestown, NY
Posted: 10/17/20 12:47pm Link  |  Quote  |  Print  |  Notify Moderator
You need to run antifreeze through it. I don't think air will pass through it like liquid will. Does your TT have a black tank flush? Don't forget to winterize that as well if you have one.
2020 Silverado 2500HD LT, CC, 4X4 6.6 Duramax
2021 Grand Design Reflection 311BHS
You can't put a porcupine in a barn, set it on fire, and expect to make licorice.
aftermath
Washington State
Posted: 10/17/20 10:35pm Link  |  Quote  |  Print  |  Notify Moderator
I use air only and have been fine for these last 11 winters. Blow the lines then run your pump dry. Blow the lines again and all the water that came out of your pump will be blown out.
IF you have a bypass, putting some antifreeze in your water pump isn't a bad idea. I don't have one and have little usable space to install one. I follow the suggestions by my local Airstream dealer, air only. This is how they winterize all of their trailers and all of their customers trailers.
2017 Toyota Tundra, Double Cab, 5.7L V8
2006 Airstream 25 FB SE
Equalizer Hitch
wtmtnhiker
New Hampshire
Posted: 10/18/20 05:32am Link  |  Quote  |  Print  |  Notify Moderator
Thanks to all for the replies. I do have a bypass and will run a bit of AF through the pump to the toilet just to be safe.
deltabravo
Spokane, WA
Posted: 10/18/20 08:04am Link  |  Quote  |  Print  |  Notify Moderator
I run air air through my lines, but I also use the winterization hose to run a small amount of AF through the pump too.
Here's how I do it.
2018 Timber Ridge 24RLS (bought pre-owned 3/12/20)
mbopp
Henrietta, NY, USA
Posted: 10/18/20 08:27am Link  |  Quote  |  Print  |  Notify Moderator
You could blow air through the winterizing line but I'd also unscrew the pump strainer and empty it.
2017 Grand Design Imagine 2650RK
2019 F250 XLT Supercab
Just DW & me......
