RV.Net Open Roads Forum: Tech Issues: Hard lesson learned on water heater anode.
 > Hard lesson learned on water heater anode.
Boomerweps
Hills of PA
Posted: 10/17/20 12:34pm Link  |  Quote  |  Print  |  Notify Moderator
Clogged toilet valve supply and sink faucet. TT bought new April 2018, checked anode when winterizing, 2018, 70-80% remaining. 2019 30-40% remaining. Only went camping once this year recently. I dewinterized and sanitized the the FW tank in late May. Ordered in new anode and water heater cleaning wand after removing the toilet to clean out the flush valve screen. Anode completely gone, flushed out much debris.
I will NEVER go over two camping seasons/years on anode replacement and at about $6 a rod shopping around, one per year is cheap insurance.
STRONGLY recommend getting the water heater cleaning wand and using it, as a minimum, when winterizing examining/replacing the anode.
2019 Wolf Pup 16 BHS Limited, axle flipped
2019 F150 4x4 SCrew SB STX 5.0 3.55 factory tow package, 7000#GVWR, 1990 CC
Camping near Pearsonville, CA
Posted: 10/17/20 12:45pm Link  |  Quote  |  Print  |  Notify Moderator
If there is a downside to RVing it is how lack of maintenance comes back to bite you.
wopachop
Who run bartertown
Posted: 10/17/20 01:01pm Link  |  Quote  |  Print  |  Notify Moderator
Shine a light and feel around where you can. I had stubborn deposits. Was told a vinegar flush is safe.
Im a dum dum. Bought the trailer used. Pulled the anode rod. Looked pretty long to me. Like a long wire. Put it back in and waited 6 months. Came to find out that was a totally used up anode rod!!!! Didnt realize the darn thing was supposed to be a half inch thick.
Lynnmor
Red Lion
Posted: 10/17/20 02:43pm Link  |  Quote  |  Print  |  Notify Moderator
Actually they are about 3/4" diameter.
GDS-3950BH
DC
Posted: 10/17/20 02:49pm Link  |  Quote  |  Print  |  Notify Moderator
Installing a new anode will still shed as much sacrificial material off as an older one taking into account the older rod still has sacrificial material remaining, and the water chemistry is the same. So installing new may make you feel better, but its not going to stop aerator screens and such from clogging. A solution looking for a problem.
beemerphile1
Ohio
Posted: 10/17/20 08:39pm Link  |  Quote  |  Print  |  Notify Moderator
Not only RVing. The most expensive maintenance is deferred maintenance.
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
Edd505
Elephant Butte, NM
Posted: 10/17/20 10:27pm Link  |  Quote  |  Print  |  Notify Moderator
don't go the cheapest route get a good Magnesium rod, cost a bit more. Sacrifices faster to save the tank. Small price to pay, under $15, I carry a spare.
2015 F350 FX4 SRW 6.7 Crew, longbed - 2017 Durango Gold 353RKT
2006 F350 SRW 6.0 crew longbed sold
2000 F250 SRW 7.3 extended longbed airbags sold
2001 Western Star 4900EX sold
Jayco Eagle 30.5BHLT sold, Layton 24.5LT sold
MitchF150
Puyallup, WA
Posted: 10/17/20 10:48pm Link  |  Quote  |  Print  |  Notify Moderator
Question to OP.. Did you leave water in the HW tank between trips? The only reason I ask is I now have the brand that has the rod.... I had the other brand before and never an issue.. Wish I had that brand!
Anyway, since I don't, I drain the HW tank between trips. I've checked the rod after using it about 5 times for 4 day long weekend trips with about 4 weeks between trips during the summer.
It still looks brand new.
I know they are cheap, but if all I need to do is drain the tank between trips, I'll do that.
Sure, if you are full time or using it every weekend... Well, not so much!
Thanks, Mitch
edatlanta
Maplesville, AL Home Base
Posted: 10/18/20 05:45am Link  |  Quote  |  Print  |  Notify Moderator
I fulltime and change my anode rod every year. Some years it is used up more and some less, but for the price - why risk the heater tank.
Ed
KM4STL
2006 GMC 2500HD CCSB 4x4 Duramax/Allison, Titan 52 gallon fuel tank, Prodigy Controller, B&W Companion Hitch, Progressive Industries EMS-PT50C, TST Systems 507 TPMS
2010 Jayco Designer 35RLTS,Cummins/Onan RV QG 5500 EVAP
Fulltime since 2010
Boomerweps
Hills of PA
Posted: 10/18/20 08:32am Link  |  Quote  |  Print  |  Notify Moderator
The TT was Dewinterized and sat with systems full of water till the October camping. I keep my TT plugged in while in storage. While the water heater is turned off, the chassis ground eddy current might be affecting the anode, too.
The sink faucet will be removed soon because the cold still has minimal flow. Hopefully, clean and replace. Otherwise, just replace with new ;(
