RV.Net Open Roads Forum: Tech Issues: Hard lesson learned on water heater anode.
 > Hard lesson learned on water heater anode.
Rover_Bill
NE. Ohio
Posted: 10/18/20 09:58am Link  |  Quote  |  Print  |  Notify Moderator
Boomerweps wrote:
Clogged toilet valve supply...
[emoticon]
Does your toilet use HOT water for flushing? I hope you're using an inline water filter on your water supply - both city water connection and to fill your fresh water tank. [emoticon]
Boomerweps
Hills of PA
Posted: 10/20/20 09:08am Link  |  Quote  |  Print  |  Notify Moderator
Rover_Bill wrote:
[emoticon]
Normally use an inline filter.
The theory was draining with the low point drains with the water heater not bypassed can pull crud in to the cold water line. I don’t know, but the crud looked suspiciously like that seen on the anode rod previously.
I did not use a filter when filling the tank when I was adding bleach for sanitizing.
It could have been an algae from the water setting for most of five months BUT the water stank of chlorine with initial use when I finally went camping.
Won’t dewinterize until within days of camping next time.
2019 Wolf Pup 16 BHS Limited, axle flipped
2019 F150 4x4 SCrew SB STX 5.0 3.55 factory tow package, 7000#GVWR, 1990 CC Tow mirrors, TBC
Rover_Bill
NE. Ohio
Posted: 10/21/20 09:23pm Link  |  Quote  |  Print  |  Notify Moderator
Hmm.. Learned something new! Don't open the low point drains until after the water heater has been bypassed. Thanks for the tip! [emoticon]
