RV.Net Open Roads Forum: Tech Issues: Advice on inverter size
 > Advice on inverter size
Itinerant1
Itinerant
Posted: 10/17/20 03:59pm Link  |  Quote  |  Print  |  Notify Moderator
2oldman wrote:
wopachop wrote:
So besides price and having to run thicker wires, is there a negative to installing a 2000w inverter that will mostly supply 200w of power?
No, and you don't even need thicker wire UNTIL you ask it for a thousand watts or so.
It's very nice to make coffee or toast with batteries instead of having to fire up a generator. Yes, I know there are another million ways to make coffee.
We aren't cavemen and not everything has to be cooked over a flame. I'm your boat hit the switch on the coffeemaker or microwave and use batteries and solar. [emoticon]
12v 500ah (5,120Wh usable) , 20 cells_ 4s5p (GBS LFMP battery system). 8 CTI 160 watt panels (1,280 watts) 2s4p. Panels mounted flat on the roof. Magnum PT100 controller, Magnum 3012 hybrid inverter, ME-ARC 50. Installed 4/2016 been on 24/7/365
wopachop
Who run bartertown
Posted: 10/17/20 04:31pm Link  |  Quote  |  Print  |  Notify Moderator
Can you guys recommend brands to check out? If i went with a larger size i could mount it behind my distribution panel and use the existing 120v wiring to make some of the outlets hot.
I wasnt sure if you could categorize them roughly by common sizes. To help determine what would be a good fit. Maybe there are solid 1000w choices, then you move up to something to act like a regular 15 circuit in the 1800-2000 range? Then go even higher from there.
I think it would be nice to support 15 amps. Brew coffee on the non caveman days.
MEXICOWANDERER
las peƱas, michoacan, mexico
Posted: 10/17/20 04:38pm Link  |  Quote  |  Print  |  Notify Moderator
Samlex
mena661
Posted: 10/17/20 04:40pm Link  |  Quote  |  Print  |  Notify Moderator
Some of those large inverters (and even some small one's) have a provision for an on/off switch. If you're concerned about power draw on the 2000W, just buy an on/off switch for it.
Trojan L16 6V's 740 Amp-hours
BFL13
Victoria, BC
Posted: 10/17/20 04:55pm Link  |  Quote  |  Print  |  Notify Moderator
Hey Mena, where have you been? Or did they let you out early for good behaviour [emoticon]
We use this one. No trouble for over two years now. You can get the on/off remote for it (good idea) . We just leave it on the whole time we are off grid. Have the shore cord plugged into it (via adapter) and the converter turned off. Simple. Practise power management.
You can't stuff a big one behind places like a little one can go, because they need lots of cooling air around them. You need to mount the inverter close to the batteries too, so somewhere up front under whatever is against the front wall in the TT, so you have short fat wires out to the tongue where the batts are. (Drill hole in floor up front to pass the wires down and then up outside--do not drill through the front cap!)
I see they are out of stock for the moment--
https://powermaxconverters.com/product/pmx-2000w-psw/
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
Dusty R
Charlotte Michigan 48813
Posted: 10/17/20 04:57pm Link  |  Quote  |  Print  |  Notify Moderator
You can get a 12 volt TV.
pianotuna
Regina, SK, Canada
Posted: 10/17/20 05:16pm Link  |  Quote  |  Print  |  Notify Moderator
I would try it before buying a larger inverter
Regards, Don
pianotuna
Regina, SK, Canada
Posted: 10/17/20 05:20pm Link  |  Quote  |  Print  |  Notify Moderator
15 amps X 120 volts = 1800 watts x 1.25% = 2250 watts rating for inverter.
Fisherman
Angus, Ontario, Canada
Posted: 10/17/20 05:33pm Link  |  Quote  |  Print  |  Notify Moderator
I use a 300 Watt pure sine for the TV and Satellite receiver and it has never even kicked the fan on. For those that run the coffee pot and toaster from an inverter, it's going to take a lot longer to charge the battery than the 10 minutes the generator would be running to make coffee and toast.
BFL13
Victoria, BC
Posted: 10/17/20 05:52pm Link  |  Quote  |  Print  |  Notify Moderator
If you are off grid here in a provincial park, you can't run the gen until 9am. (At least that is the rule. There are always those that think the rules don't apply to them!) So for breakfast earlier than that, it is inverter for proper toast in a real toaster instead of that bread-burner stupid thing that goes on the propane stove top for maximum smoke--setting of the fire alarm and that makes the dogs bark--not cool [emoticon]
Once gen hours start you can recharge the batts
