RV.Net Open Roads Forum: Class A Motorhomes: Brake Fluid Still Milky
 > Brake Fluid Still Milky
dwayneearle
Ontario Canada
Posted: 10/17/20 01:53pm Link  |  Quote  |  Print  |  Notify Moderator
Hey everyone super stumped.
Changing my 2003 Ford F53 DOT3 brake fluid due to rebuilding my rear calipers.
When bleeding the old dark fluid came out pretty quickly but then milky amber fluid immedietly followed (water contamination). Sucked out all of the old resevoir fluid and replaced but still the milky fluid persists even after 5.2 quarts.
What am I missing??
2006 Chevrolet Trailblazer EXT
2005 R Vision TC26QHB
wolfe10
Posted: 10/17/20 02:18pm Link  |  Quote  |  Print  |  Notify Moderator
Perhaps someone added something else other than the correct brake fluid some time in the last 17 years.
* This post was edited 10/17/20 02:26pm by wolfe10 *
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
time2roll
Posted: 10/17/20 02:21pm Link  |  Quote  |  Print  |  Notify Moderator
Did you bleed all four wheels? I recommend a pressure bleeder.
If the brakes feel good I would be tempted to run it as is and plan on an annual flush until it comes through clear.
675w Solar pictures back up
rgatijnet1
Posted: 10/17/20 02:25pm Link  |  Quote  |  Print  |  Notify Moderator
What fluid are you using? Not all fluids are compatible with each other.
My WH chassis took about 3 quarts for a complete flush. If you have a small pin hole leak you may be sucking some air and causing it to foam up, which gives it the milky appearance. Let some of the milky fluid sit for awhile and see if it clears up.
carringb
Corvallis, OR
Posted: 10/17/20 02:46pm Link  |  Quote  |  Print  |  Notify Moderator
Yup. Keep flushing. There's probably a bunch trapped in the accumulators in the ABS pump, but you need a diagnostics terminal to cycle the pump when bleeding. For a DIY, just drive a while then flush again.
Bryan
2014 ORV really big trailer
2015 Ford Focus ST
MountainAir05
New Mexico
Posted: 10/17/20 03:17pm Link  |  Quote  |  Print  |  Notify Moderator
If you have vacuum pump system, you can rig up a freon can and pull a vacuum on it and use that to suck out the fluid from the right rear and suck it clear and move to each one. As someone stated you could have a pin hole in one of those flex hoses also. But that should show up on the rear and not the fronts.
K Charles
Connecticut
Posted: 10/17/20 05:14pm Link  |  Quote  |  Print  |  Notify Moderator
Did someone put DOT5 in it at one time?
azdryheat
Tucson, AZ
Posted: 10/17/20 05:29pm Link  |  Quote  |  Print  |  Notify Moderator
Keep flushing.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2016 RZR 900
Ava
Vancouver Island. BC Canada
Posted: 10/17/20 10:13pm Link  |  Quote  |  Print  |  Notify Moderator
Do you have a Hydromax power brake system with the backup electric motor? If so, keep the brake fluid cap on the reservoir while bleeding. I had the same thing while bleeding front brakes and left the top off. With the reservoir cover on I waited overnight and tried again with success.
