RV.Net Open Roads Forum: Fifth-Wheels: BW 3300 with Ford 6.5 box
 > BW 3300 with Ford 6.5 box
spud1957
NB
Posted: 10/17/20 02:31pm Link  |  Quote  |  Print  |  Notify Moderator
Anyone have this set up? Truck has the pucks. Not to excited about buying a slider. Also considering the Anderson.
Thermoguy
Graham, WA
Posted: 10/18/20 10:14am Link  |  Quote  |  Print  |  Notify Moderator
Before you buy an Anderson, look at the pictures on Amazon.
I have a short box chev with a B&W Companion. Great hitch, solid. I don't have a slider so I have to be careful when backing. My trailer is older so it is square up front. I don't think I need a slider.
cummins2014
Utah
Posted: 10/19/20 09:30am Link  |  Quote  |  Print  |  Notify Moderator
I tow with the Andersen ,and also a short bed . Yes I would think you have to be careful, I have the rounded corners on mine which is newer ,and no real issues with the Andersen .
I have since turned the Andersen adapter around ,putting the fifth wheel closer to the cab, putting the pin slightly forward on the axle, instead of rear of center. Still not issue backing up.
Cummins12V98
on the road
Posted: 10/19/20 11:27am Link  |  Quote  |  Print  |  Notify Moderator
No problem til there is!!!
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Njmurvin
Simi Valley
Posted: 10/19/20 11:48am Link  |  Quote  |  Print  |  Notify Moderator
Assuming you can hit the cab with all conventional non-slider hitches, your best shot at avoiding a slider is likely the Andersen. The hitch, itself, gives you 5" of setback from the cab. Then, add about 4" to that if you can get away with the standard install of the kingpin adapter. Assuming your pinbox has clearance from the bedrails and tailgate in that position (as mine does), you gain a healthy 9" in total.
I had a Superglide in my previous truck and I loved how I never had to worry about hitting the cab. What I didn't love was getting the hitch in and out of the truck and its robbing me of 250lbs of payload. It literally takes me 15 minutes to install my Andersen (all 38lbs of it) and I take my time. My truck has a slightly longer bed (6'10") and I have miles of clearance to the cab in tight turns.
2020 Chevy Silverado 3500HD Duramax 4x4 Crew Cab Standard box
2011 Arctic Fox 27.5L
cummins2014
Utah
Posted: 10/19/20 12:15pm Link  |  Quote  |  Print  |  Notify Moderator
I had to laugh on that one [emoticon] Pretty sure that applies to everything .
Cummins12V98
on the road
Posted: 10/19/20 12:42pm Link  |  Quote  |  Print  |  Notify Moderator
If you have to worry about 212# you are pushing it.
cummins2014
Utah
Posted: 10/19/20 02:45pm Link  |  Quote  |  Print  |  Notify Moderator
If you had to add another 212 # with your setup would you , with already being over your weight ratings , or close to it ???
Njmurvin
Simi Valley
Posted: 10/19/20 06:56pm Link  |  Quote  |  Print  |  Notify Moderator
Not "pushing it" on this truck (3900lb payload).
The real point of my post was the added cab clearance the AUH can provide. The weight benefit is secondary - but by all means, not insignificant.
cummins2014
Utah
Posted: 10/20/20 09:07am Link  |  Quote  |  Print  |  Notify Moderator
My kingpin is at the same distance from my cab with the adapter for the Andersen in the forward position putting it closer to the cab as it was with my Reese slider in the tow position. I have no issues backing my fifth wheel .
We just returned from a hunting trip, and as always I have a tight turn to get into my RV pad beside my home . The pad is 10 feet wide , my house on one side ,and property line ,and trees on the other, its a tight fit . I have to crank it pretty tight ,not an issue . I would say I am in the 70 degree range, a lot tighter then I want to on dry pavement., and cement. As one asked can I go 90 degrees ,no . I can get close ,but getting in my driveway is as tight as I have ever had to go.
