RV.Net Open Roads Forum: Champion #100263 - 3400 Dual Fuel elect Start?
 > Champion #100263 - 3400 Dual Fuel elect Start?
Dtank
Posted: 10/17/20 03:46pm Link  |  Quote  |  Print  |  Notify Moderator
Report on "Impressions" if you have one - and price/s??
Thanks!
On edit: My bad! Should have been posted to "Tech Issues" forum.
"Notify Moderator" won't fly.......so Mod/s if you see this pliz move over to Tech. Thanks again!
* This post was edited 10/17/20 04:01pm by Dtank *
pianotuna
Regina, SK, Canada
Posted: 10/17/20 05:22pm Link  |  Quote  |  Print  |  Notify Moderator
generators that run on propane are fine, but they ARE hungry.
Regards, Don
valhalla360
No paticular place.
Posted: 10/17/20 05:45pm Link  |  Quote  |  Print  |  Notify Moderator
Helped friends pick one out this summer.
Works nice but as mentioned, propane supply is an issue.
For the friends, it's not an issue as they are in a permanent site and are getting a big tank brought out to the site.
If you are out boondocking, it becomes really limiting and a hassle getting 30lb tanks refilled.
Tammy & Mike
Ford F250 V10
2008 Copper Canyon 5er
Catalac Catamaran 34'
Full Time spliting time between boat and 5er
TechWriter
On The Road
Posted: 10/17/20 05:48pm Link  |  Quote  |  Print  |  Notify Moderator
I run my Champion 4375 on propane and haven't noticed excessive propane use. It's a good generator. I use mine for park model backup power.
2001 Newmar Mountain Aire 4095 DP
Full Timer since May 2013
www.rvSeniorMoments.com
DISH TV for RVs
Thermoguy
Graham, WA
Posted: 10/18/20 09:56am Link  |  Quote  |  Print  |  Notify Moderator
I have a Champion Dual Fuel also. Ran it for 4 days on 2 bottles of propane this summer, mostly to run the A/C. Still had some propane left. Not sure if that is excessive or not. Without looking, I think mine is the 4375 or similar.
MrWizard
Traveling
Posted: 10/18/20 02:16pm Link  |  Quote  |  Print  |  Notify Moderator
I dislike using pounds for measuring propane use
A 30# tank is 7 gallons, a 20# tank is close to 5 gallons
Propane has less energy per gallon than Gasoline
So running the A/C uses more gallons of LP than Gas
Only You can compare your fuel costs more gallons of LP verus lesser gallons of Gasoline
Gasoline is usually easier to aquire and cost less per hour of use,
For home backup, where a large bulk tank is there for normal residential use , LP makes sense, For me it doesn't make sense for boondocking IF it will be used, on a regular basis
I lived in a Safari DP with propane Onan for 10 years, during a hot Midwest summer camping, i burned thru 100# aka 20+ gallons every 3 days using that Onan for the 2 rooftop A/Cs
The champion dual fuel generator, is a nice one
If the the price is right go for it,
But i would not use LP fuel , as my normal use fuel,
But it does give an option to continue use, if out of Gasoline, when camping with an RV where removal refillable bottles/tanks are the norm
Radiate The Happy
1997 F53 Bounder 36s
Edd505
Elephant Butte, NM
Posted: 10/18/20 06:19pm Link  |  Quote  |  Print  |  Notify Moderator
I have a hand start Champion 3500 and love it, wish it was electric start. I wouldn't have to get out of bed to start.
2015 F350 FX4 SRW 6.7 Crew, longbed - 2017 Durango Gold 353RKT
2006 F350 SRW 6.0 crew longbed sold
2000 F250 SRW 7.3 extended longbed airbags sold
2001 Western Star 4900EX sold
Jayco Eagle 30.5BHLT sold, Layton 24.5LT sold
