RV.Net Open Roads Forum: Tech Issues: Fridge issue
 > Fridge issue
Cougargm
NE PA
Posted: 10/17/20 07:39pm Link  |  Quote  |  Print  |  Notify Moderator
We overloaded our generator and while the genny was running, nothing was working. Simply hit the reset and everything worked- except the fridge & furnace. Found a blown fuse, replaced it and the furnace worked fine. Unfortunately the fridge still isn't working. Unplugged it for awhile, hoping it would start once plugged in again, but nothing. It won't turn on at all, so I can't even pick LP mode let alone electric. Any suggestions as to what I should try or look for next? THanks in advance!
Dutch_12078
Winters south, summers north
Posted: 10/17/20 07:50pm Link  |  Quote  |  Print  |  Notify Moderator
Make and model of the fridge might help us help you better. Are you getting 12 volts at the fridge?
Dutch
2001 GBM Landau 34' Class A
Cougargm
NE PA
Posted: 10/17/20 07:59pm Link  |  Quote  |  Print  |  Notify Moderator
It's a Norcold. The Class C is 15 yrs old and I believe the fridge is as well. (not original owner). I haven't checked the voltage but it won't power on at all, as I can't even select LP or AC for the mode.
Vw triker
Millboro, va
Posted: 10/17/20 08:03pm Link  |  Quote  |  Print  |  Notify Moderator
Reset gfi's maybe?
Cougargm
NE PA
Posted: 10/17/20 08:12pm Link  |  Quote  |  Print  |  Notify Moderator
I only found one GFI in the RV and that was in the bathroom. Reset that but it didn't help.
rk911
DuPage County
Posted: 10/17/20 08:32pm Link  |  Quote  |  Print  |  Notify Moderator
we had a second gfci in an exterior storage compartment in a previous MH. check again.
Rich
Ham Radio, Sport Pilot
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
agesilaus
North Florida
Posted: 10/17/20 08:40pm Link  |  Quote  |  Print  |  Notify Moderator
OK I'm fgoing thru the same issue on my N821 Norcold (2016) w/o a power surge tho. If it is like mine there are two circuit boards, one on the front of the fridge thaqt has the display and switches called the eyebrow panel. And one in the outside access area in a black plastic box. That one has two fuses and if you are lucky one of those is blown. So check that out first thing.
I still have not fixed mine, after possibly eliminating all else it seemed to be the eyebrow panel but I ordered one from Amazon and it does not fix the fridge. Some I'm still stumped. That was $160 but is returnable.
There are other possibilities so let us know if it is not the fuses.
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
craig7h
Branson MO area
Posted: 10/18/20 03:30am Link  |  Quote  |  Print  |  Notify Moderator
If you have found and reset the GFI's get a meter and see if you are getting power to the 120v outlet the frig is plugged into. Lets say you have power at the outlet.
You will need to take off the black cover from the control board for the frig. It should be located on the back side of the frig, but you can get to it through the outside access panel. The control panel will have two fuses one being a long one and the other a push in type. Sorry I do not know the correct name for the two types of fuses. Check them make sure they are both good. You did not say if you reset the breaker for the frig on the breaker panel. You may want to check that, turn it off then back on. Good Luck
Itasca Meridian SE 36g
Road Master Tow Dolly
MEXICOWANDERER
las peƱas, michoacan, mexico
Posted: 10/18/20 03:58am Link  |  Quote  |  Print  |  Notify Moderator
It's a BATTERY DC ISSUE. Meaning anywhere from the battery to and through the control board.UNPLUG FOR SAFETY. Then go outside to the access panel and check 12 volt wire going into refrigerator. Does it have power?
enblethen
Moses Lake, WA
Posted: 10/18/20 06:58am Link  |  Quote  |  Print  |  Notify Moderator
Look closer for model number.
Does it have a circuit board in the outside access?
Does the interior display light up?
How is the unit changed from gas to electric, Knob or switch?
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
 > Fridge issue
