RV.Net Open Roads Forum: Class A Motorhomes: Coachmen Santara Capacities
 > Coachmen Santara Capacities
Bill Kirkbride
Mesquite Nevada
Posted: 10/18/20 10:40am Link  |  Quote  |  Print  |  Notify Moderator
I just purchased a 2000 Coachmen Santara 370 MB diesel pusher. 350 HP Cummins. It has a 7000 KW Onan gasoline generator.
I have downloaded the Owners Manual and searched the Internet to find out the capacities of all of the liquids. Diesel fuel tank, Generator gasoline tank, Fresh water tank, gray water tank, black water tank, propane tank, etc... I cannot find this information anywhere. Does anyone have the same type RV that can provide this information? Thanks in advance for any help. Bill
DrewE
Vermont
Posted: 10/18/20 10:57am Link  |  Quote  |  Print  |  Notify Moderator
Many of those should be on the weight (CCC/OCCC) sticker which is often on the back wall of a cabinet somewhere. At the very least it would have the fresh water and propane tank capacities.
The propane tank would also have the capacity stamped on the data plate on the tank itself. You'd have to take care to read whether it's the so-called water capacity or the usable capacity (which is 80% of the water capacity by volume).
Bill Kirkbride
Mesquite Nevada
Posted: 10/18/20 07:54pm Link  |  Quote  |  Print  |  Notify Moderator
Drew E
I thought the same thing, that the capacities should be shown somewhere. So far, no luck. As for the propane, I can probably figure it out by some of the writing on the tank as well as, the size. It is much bigger than a bbq tank. I'll keep searching but so far, nothing.
Bill.Satellite
Full-timer
Posted: 10/19/20 08:22am Link  |  Quote  |  Print  |  Notify Moderator
You should not have a gas tank for your generator if this is a diesel coach. The generator is likely diesel as well (hopefully) and draws front the main diesel tank. If not, the generator is likely going to be propane.
What I post is my 2 cents and nothing more. Please don't read anything into my post that's not there. If you disagree, that's OK.
Can't we all just get along?
Bill Kirkbride
Mesquite Nevada
Posted: 10/19/20 11:45am Link  |  Quote  |  Print  |  Notify Moderator
Bill Satellite
It apparently was an option on this model to have an Onan Gas Generator. I know it is gas because it has a gasoline fuel door located right next to the diesel fuel door, both are locking doors located just under the drivers side window. I have fueled it up with gasoline and the generator runs fine.
Bill Kirkbride
Mesquite Nevada
Posted: 10/19/20 11:47am Link  |  Quote  |  Print  |  Notify Moderator
Bill Satellite
Bill.Satellite
Full-timer
Posted: 10/19/20 06:03pm Link  |  Quote  |  Print  |  Notify Moderator
That's the first I've heard of such a setup! Sorry I was less than helpful!
GDS-3950BH
DC
Posted: 10/20/20 01:55am Link  |  Quote  |  Print  |  Notify Moderator
Even if someone has the exact same RV, that does not exactly mean all the tank sizes or capacities are the same. The RV Industry is notorious for making changes while slapping together RV's, hence the disclaimers that are everywhere on brochures and websites. It was the same in 2000 as it is today.
If during the production run they run out of 50 gallon holding tanks which they advertise, if a 30 is on hand and they can make it fit thats what you get. A coworker ordered a TT because of its wrap around dinette but when it arrived it had a standard sit across, the manufacturer ran out of cushions for the wrap around. Take it or leave it he was told.
They will and can change capacities, sizes, designs, brands of components, etc, on a whim, and do so all the time.
Horsedoc
Dixie --- N. Georgia
Posted: 10/20/20 09:10am Link  |  Quote  |  Print  |  Notify Moderator
Actually not Bill. The first MH we had was a DP with a gasoline generator. Coachman Santara no slides
horsedoc
2008 Damon Essence
2013 Jeep Sahara Unlimited
Blue Ox tow
PastorCharlie
NC
Posted: 10/20/20 12:47pm Link  |  Quote  |  Print  |  Notify Moderator
I once owned a Coachmen Santara and it had a 100 gallon fresh water tank, a 10 gallon hot water tank, a 18 gallon propane tank, a 45 gallon black water tank, a 55 gallon gray water tank and a 75 gallon fuel tank. IIRC
