RV.Net Open Roads Forum: Tech Issues: Old Coleman AC
 > Old Coleman AC
Kpackpackkelley
Bryan tx
Posted: 10/18/20 04:09pm Link  |  Quote  |  Print  |  Notify Moderator
Sometimes this Ac starts and runs right but sometimes starting amps go up to high and it will kick the breaker. Wanted advice on if it could be the capacitors or the compressor going out. Thanks
Matt_Colie
Southeast Michigan
Posted: 10/18/20 04:53pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, it easily could be. It is not, however, a given. Capacitors do age out.
Matt
Matt & Mary Colie
A sailor, his bride and their black dogs going to see some dry places that have Geocaches in a coach made the year we married.
Kpackpackkelley
Bryan tx
Posted: 10/18/20 05:03pm Link  |  Quote  |  Print  |  Notify Moderator
I don’t know enough to make a decision. Don’t want to spend the money on capacitors and it is the compressor going out thanks.
I had a clamp on meter on it and sometimes it would go up to 41 amps and kick the breaker. But other times I cut it on it would act normal and run right.
Bird Freak
Dallas Ga.
Posted: 10/18/20 07:53pm Link  |  Quote  |  Print  |  Notify Moderator
Mine did the same. Capacitors solved problem.
Eddie
03 Fleetwood Pride, 36-5L
04 Ford F-250 Superduty
15K Pullrite Superglide
Old coach 04 Pace Arrow 37C with brakes sometimes.
Owner- The Toy Shop-
Auto Restoration and Customs 32 years. Retired by a stroke!
We love 56 T-Birds
Wherever I happen to park
Posted: 10/19/20 06:00am Link  |  Quote  |  Print  |  Notify Moderator
Have same issue on one A/C New cap did not fix.
I will never know what it is because the Rig was clipped by a semi. Not a lot of damage but Insurance says "Totaled" so.. I've been a bit worried about my ability to continue the RV life.. Insurance gets it soon as I get it cleaned out and now it is THEIR problem.
Home is where I park it.
deltabravo
Spokane, WA
Posted: 10/19/20 06:13am Link  |  Quote  |  Print  |  Notify Moderator
First thing I'd do is replace the circuit breaker, it's an easy first step.
2018 Timber Ridge 24RLS (bought pre-owned 3/12/20, sold 7/28/20)
bazar01
Georgia
Posted: 10/19/20 07:28am Link  |  Quote  |  Print  |  Notify Moderator
41 amps is too high on a 15 amp circuit breaker. It could be capacitor or compressor. Could be a loose spade connector on the cap or compressor.
You have to take a look at it anyway so you can get the capacitor specs so do a visual on the cap, wires and spade connectors.
jjrbus
FT Myers FL
Posted: 10/19/20 07:29am Link  |  Quote  |  Print  |  Notify Moderator
RV AC seems to have a tremendous amount of misinformation on the net. I am no expert either and can only relate my experience and opinion.
41 amps. It takes decent equipment to measure the starting amps of an AC. The 41 may be right or close enough. AC has 2 amp measurements running amps and LRA locked rotor amps. A very brief less than a second amp surge from the start capacitor to kick start the compressor. inexpensive meters will not measure the LRA accurately or at all!
Need a meter that can measure farads to actually measure the health of the capacitor. Can be good but not good enough, like a weak battery. Be cautious with capacitors they can produce enough voltage to kill!
Tough call, circuit breakers can and do get weak, go bad. Capacitors can get weak. Compressor may need a hard start. No idea how to test a breaker? I can test capacitor.
cheapest easiest option is replace breaker and hope!
Kpackpackkelley
Bryan tx
Posted: 10/19/20 11:49am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the answers. I’ll let you know what I find.
Kpackpackkelley
Bryan tx
Posted: 10/19/20 06:49pm Link  |  Quote  |  Print  |  Notify Moderator
Looks like I need a new Ac.
 > Old Coleman AC
