RV.Net Open Roads Forum: Fifth-Wheels: Battery Disconnect
 > Battery Disconnect
CYOUL8R
Phoenix, AZ
Posted: 10/19/20 01:59pm Link  |  Quote  |  Print  |  Notify Moderator
I'm looking for a good place to install a battery disconnect in my 2012 Sabre.
I know I can put it down in the basement near the battery but that is inconvenient to use it there. I'm think of mounting it inside the driver's side propane compartment. I would only have the knob protruding into that compartment with the backside of the switch mounted in the driver's side of the storage compartment which has a separating wall between the propane compartment and the storage compartment. That's where the wires would be connected.
I will use the Blue Sea switch which allows for multiple mounting configurations. That way I can just open the the propane door to activate/deactivate the switch.
I don't see any arcing of the switch occurring this way in case of a propane leak but what do others think. Would this be safe?
2012 Palomino Sabre 32RCTS-6
2012 Ford F-250 Super Duty Fx4 6.7 Powerstroke
16K PullRite SuperGlide
Air Lift LoadLifter 5000 Air Bags
opnspaces
San Diego Ca
Posted: 10/19/20 02:32pm Link  |  Quote  |  Print  |  Notify Moderator
In a perfect world there is no arcing from the switch unless you are turning it on or off. In an imperfect world, well, things happen.
I would not put the switch in an enclosed area that close to the enclosed propane.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
agesilaus
North Florida
Posted: 10/19/20 02:54pm Link  |  Quote  |  Print  |  Notify Moderator
That occurred to me as well. Probably not a good idea.
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
Likes to tow
Huntington WV
Posted: 10/19/20 02:58pm Link  |  Quote  |  Print  |  Notify Moderator
I bought a disconnect at Wal Mart and it clamps to the positive lead of the battery. All the wires go to the end of it and there is a large knob to tighten it up on the battery. Works great, very quick, simple to install and simple to use....did I also mention cheap.
Super_Dave
Harrisville, UT
Posted: 10/19/20 03:29pm Link  |  Quote  |  Print  |  Notify Moderator
The propane storage compartment is heavily vented at the bottom and the door will be wide open. It would likely have to be a full on geyser of propane to be an issue, which you would surely see or smell.
However, I don't see how opening the propane door is significantly easier than opening the front storage door.
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 21' North River Seahawk
CYOUL8R
Phoenix, AZ
Posted: 10/19/20 04:58pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the replies but I think I may have not been clear with my question.
All of the wires will connect to the rear of the switch which would be contained in a storage compartment and not the propane compartment. There is a partitioned wall between the two. The only part of the switch accessible in the propane compartment would be the on/off knob.
These switches are used in marine environments and are ignition protected for use in gasoline powered applications. I have contacted the manufacturer but have not heard back yet.
Blue Sea Switch
schlep1967
Harrisburg, PA
Posted: 10/20/20 06:02am Link  |  Quote  |  Print  |  Notify Moderator
You are over thinking the battery and propane issue. My battery sits right below my propane tanks from the factory. The disconnect switch is mounted on the bulkhead right next to the tanks with the operating side away from the tanks in the passenger side storage compartment. All the wires and connections are right next to the tanks.
Pretty much the opposite of what you are saying you want to do.
2008 Dodge Ram 2500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide
