RV.Net Open Roads Forum: spartan says they don't carry it looking for radiator
 > spartan says they don't carry it looking for radiator
TomandCandy
Olympia, WA
Posted: 10/19/20 09:43pm Link  |  Quote  |  Print  |  Notify Moderator
looking for a replacement radiator if all does not go well when I take it to radiator shop this is on a 1996 spartan 230 hp 6 speed allision called Spartan for a plan B and they said they don't carry it thanks in advance Tom
Old-Biscuit
Verde Valley
Posted: 10/19/20 10:40pm Link  |  Quote  |  Print  |  Notify Moderator
Radiator shop should be able to get replacement if unable to fix yours
US NAVY------USS Decatur DDG31
rgatijnet1
Posted: 10/20/20 04:54am Link  |  Quote  |  Print  |  Notify Moderator
Any good radiator shop will dismantle your old radiator and keep the upper and lower tanks and mounting brackets. Then they will replace the core with an off the shelf unit to replace your old radiator core. The problem is that most shops cannot deal with an RV so you must remove the radiator and take it to them.
Posted: 10/20/20 06:04am Link  |  Quote  |  Print  |  Notify Moderator
There are two kinds of shops now days. OLD and NEW
The new shops are just replacement shops You bring you ride in they figure out what is bad and order a new one and put it in. Easy Peasy.
But the old style shops FIXED things.. A raditor for example has several modules The upper tank, lower tank, Transmission cooler (often part of lower tank) and so on.. What a Radiator REPAIR shop does is remove the top and bottom tanks if they are good RE-CORE the thing (that is the heat exchanger part) and put it back in... Unless the problem is a bad tank. these shops should be able to fix ANY radiator.
larry cad
ohio
Posted: 10/20/20 06:38am Link  |  Quote  |  Print  |  Notify Moderator
Radiator on my 2000 Spartan chassis started leaking late last year. I removed the radiator myself and took it to a local radiator shop. The completely rebuilt it for less than the radiators I found online to replace mine. I put it in and have just returned from a 6000 mile cross country journey and all is well.
Our Travel Blog
noteven
Turtle Island
Posted: 10/20/20 06:44am Link  |  Quote  |  Print  |  Notify Moderator
Radiator shop yup.
TomandCandy
Olympia, WA
Posted: 10/20/20 07:23pm Link  |  Quote  |  Print  |  Notify Moderator
going to radiator shop tomorrow finally got that bugger out of there they silicone the radiator to the air charger and also to the transmission cooler I had to cut those lines out on transmission cooler so looks like a radiator repair and weld new connections back on cooler ya I could of used stop leak but I couldn't do that to the next owner of this coach as we are looking for a newer coach now I think most of us are that way with a motorhome we meet great people rving all the time ok later.
Ray,IN
IN, USA
Posted: 10/24/20 08:49am Link  |  Quote  |  Print  |  Notify Moderator
This fits a 1988 - 1992 Spartan chassis.
And so, my fellow Americans: ask not what your country can do for you — ask what you can do for your country.John F. Kennedy 20Jan1961
carringb
Corvallis, OR
Posted: 10/24/20 11:12am Link  |  Quote  |  Print  |  Notify Moderator
MAC's radiator will rebuild your radiator, and they probably have the dimensions on hand to built a new one if you prefer.
2014 ORV really big trailer
2015 Ford Focus ST
